[Mapbender-users] problem with wfs conf
Marec
marec at t-online.de
Wed Aug 29 13:29:20 EDT 2007
Hi Christian,
I´ve had a similar problem here.
Try to update folowing file from current source code:
I think, there are some differents in this file like in my case.
mapbender2.4/http/frames/index.php
greetings Marc
http://geoportal.remscheid.de
Christian.Strobl at dlr.de schrieb:
> hi mapbender users,
> i have the next problem. if i want to configure a wfs (geoserver), i get
> the following error message:
> Warning: pg_exec() [function.pg-exec]: Query failed: ERROR: syntax error
> at or near ";" at character 77 in
> C:\Programme\mapbender\mapbender_2.4.2\mapbender_2.4.2\http\php\database
> -pgsql.php on line 133
> Warning: pg_exec() [function.pg-exec]: Query failed: ERROR: operator
> does not exist: integer <> HINT: No operator matches the given name and
> argument type(s). You may need to add explicit type casts. in
> my configuration:
> Mapbender 2.4.2
> Php Version: 5.1.4
> PostgreSQL 8.1.4
> POSTGIS="1.1.2" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
> thanks for your help
> christian
> p.s. the load wfs operation worked successfully
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
