[Mapbender-users] problem including wms from localhost
Samson, Marko
Marko.Samson at wald-und-holz.nrw.de
Thu Dec 13 05:32:12 EST 2007
with reference to your second problem:
You are using Windows, so you have to use
http://localhost:81/mapserver/mapserv.exe?
Have a look into your Mapfile. It seems, that you have WMS_ONLINERESOURCE configured like that:
http://localhost:81/mapserver/mapserv? (missing .exe!)
The value from WMS_ONLINERESOURCE ,taken from the getcapabilities-request reply, is saved into the mapbender database and will be used for the getmap,getlegend,... request in your gui.
After changing the mapfile you have to update the wms at the mapbender services gui (perhaps have a look at the preview before updating, and check for errors in the capabilities document), because of the saved request-urls at table wms.
Greetings,
Marko Samson
From: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of karsten vennemann
Sent: Wednesday, December 12, 2007 9:50 PM
To: mapbender_users at lists.osgeo.org
Subject: [Mapbender-users] problem including wms from localhost
Hi Mapbender List,
I'm new to mapbender, and specifically setting up wms with mapserver .
So far mapbender 2.4.3 is running great on my windows XP box under Apache J.
I created a new gui and wanted to include a new wms which I (tried) to create with mapserver.for the last week L .
Finally I kind of succeded "halfway" and got
http://localhost/mapserver/mapserv.exe?map=/mapserver/ok.map&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=People1
to deliver an image in Firefox.
Mapbender let me upload the capabilities of the wms only if I use version 1.1.0 - not when I used 1.1.1
(then I got this in my log file :
2007.12.12, 11:51:36,db_query(UPDATE wms SET wms_version = '' ,wms_getcapabilities = '' ,wms_getmap = '' ,wms_getfeatureinfo = '' ,wms_getlegendurl = '' ,wms_getcapabilities_doc = 'MZ' ,wms_upload_url = 'http://localhost:81/mapserver/mapserv.exe?map=ok.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1', wms_owner = 1, wms_timestamp = 1197489096 WHERE wms_id = 913)= db_error=ERROR: invalid byte sequence for encoding "UTF8": 0x90
HINT: This error can also happen if the byte sequence does not match the encoding expected by the server, which is controlled by "client_encoding"
What does that mean with the encoding ?
Also sometimes I find in my log files lines like
2007.12.12, 12:30:16,Conversion: ISO-8859-1 to UTF-8
Why is that ? Is that a problem and how can I fix it ?
Ok now when I join my wms to my GUI it shows up on the legend but the layer doesn't display on the map but I get this error:
Faied to load WMS "ocla" from server http://localhost:81/mapserver/mapserv?map=ok.map"
Do you weant to try to load it in a new window?
Once I open that in Firewfox I get:
Not Found
The requested URL /mapserver/mapserv was not found on this server.
What could be wrong ?
Also I don't know why it strip out the information I put in when up loading the capabilities it displays
when I put in
Any ideas?
more detailed infos see below
Thanks
Karsten
In Mapbender admin I uploaded the wms and got this information - does that look ok?
file: http://localhost/mapserver/mapserv.exe?map=ok.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0
version: 1.1.0
title: ocla
abstract:
maprequest: http://localhost:81/mapserver/mapserv?map=ok.map&
capabilitiesrequest: http://localhost:81/mapserver/mapserv?map=ok.map&
featureinforequest: http://localhost:81/mapserver/mapserv?map=ok.map&
gui_wms_mapformat: image/png
gui_wms_featureinfoformat: text/plain
gui_wms_exceptionformat: application/vnd.ogc.se_inimage
gui_wms_epsg: EPSG:4326
wms_srs: epsg:4326
gui_wms_visible: 1
map -> image/gif
map -> image/png
map -> image/png; mode=24bit
map -> image/jpeg
map -> image/wbmp
map -> image/tiff
featureinfo -> text/plain
featureinfo -> application/vnd.ogc.gml
exception -> application/vnd.ogc.se_xml
exception -> application/vnd.ogc.se_inimage
exception -> application/vnd.ogc.se_blank
id: 1 parent: 0 name: People1 title: people queryable: 1 minScale: 0 maxScale: 0
dataurl:
metadataurl:
EPSG:4326
661172
-527873
2.63636e+006
751825
layerstyle:
name
title
legendurl
legendurlformat
default
default
http://localhost:81/mapserver/mapserv?map=ok.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=People1&format=image/png
image/png
And finally here is what I have in my map file:
# Start of map file
NAME "ocla"
EXTENT 600000 -800000 2750000 1000000
SIZE 400 400
UNITS FEET
IMAGECOLOR 204 221 255
IMAGETYPE PNG
INTERLACE OFF
#### Start of projection definition ###################
# NAD83 / Washington North (ftUS) EPSG <2285>
PROJECTION
"init=epsg:4326"
END
# Start of web interface definition##############################
WEB
IMAGEPATH "D:/web/sites/mapserver/tmp/"
METADATA
# "wms_title" "terragis"
"wms_onlineresource" "http://localhost:81/mapserver/mapserv?map=ok.map"
"wms_srs" "epsg:4326"
END
END
# Start of layer definitions##################################
LAYER
NAME "People1"
TYPE POLYGON
DATA "D:/web/sites/mapserver/wsba/mapdata/layers/tracts"
metadata
"wms_srs" "EPSG:4326"
"wms_title" "people"
"wms_exceptions_format" "application/vnd.ogc.se_xml"
"wms_server_version" "1.1.1"
"wms_formatlist" "image/png"
"wms_format" "image/png"
end
dump true
PROJECTION
"init=epsg:4326"
END
TEMPLATE "template"
TOLERANCE 3
STATUS ON
CLASS
NAME "Up to 5"
EXPRESSION ([INSTITUTN] >= 0 AND [INSTITUTN] <= 5)
STYLE
COLOR 112 153 89
END
END
CLASS
NAME "6 - 50"
EXPRESSION ([INSTITUTN] >= 5 AND [INSTITUTN] <= 50)
STYLE
COLOR 178 194 141
END
END
END
END # Map File
More information about the Mapbender_users
