[Mapbender-users] problem including wms from localhost
karsten vennemann karsten at terragis.net
Wed Dec 12 15:49:56 EST 2007
Hi Mapbender List,
I’m new to mapbender, and specifically setting up wms with mapserver .
So far mapbender 2.4.3 is running great on my windows XP box under Apache
I created a new gui and wanted to include a new wms which I (tried) to
create with mapserver.for the last week :-( .
Finally I kind of succeded “halfway” and got
http://localhost/mapserver/mapserv.exe?map=/mapserver/ok.map
<http://localhost/mapserver/mapserv.exe?map=/mapserver/ok.map&VERSION=1.1.1&
REQUEST=GetMap&SERVICE=WMS&LAYERS=People1>
&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=People1
to deliver an image in Firefox.
Mapbender let me upload the capabilities of the wms only if I use version
1.1.0 – not when I used 1.1.1
(then I got this in my log file :
2007.12.12, 11:51:36,db_query(UPDATE wms SET wms_version = ''
,wms_getcapabilities  = '' ,wms_getmap  = '' ,wms_getfeatureinfo  = ''
,wms_getlegendurl  = '' ,wms_getcapabilities_doc = 'MZ' ,wms_upload_url =
'http://localhost:81/mapserver/mapserv.exe?map=ok.map&REQUEST=GetCapabilitie
s&SERVICE=WMS&VERSION=1.1.1',  wms_owner = 1, wms_timestamp = 1197489096
WHERE wms_id = 913)= db_error=ERROR:  invalid byte sequence for encoding
"UTF8": 0x90
HINT:  This error can also happen if the byte sequence does not match the
encoding expected by the server, which is controlled by "client_encoding"
What does that mean with the encoding ?
Also sometimes I find in my log files lines like
2007.12.12, 12:30:16,Conversion: ISO-8859-1 to UTF-8
Why is that ? Is that a problem and how can I fix it ?
Ok now when I join my  wms to my GUI it shows up on the legend but the layer
doesn’t display on the map but I get this error:
Faied to load WMS “ocla” from server
http://localhost:81/mapserver/mapserv?map=ok.map”
Do you weant to try to load it in a new window?
Once I open that in Firewfox I get:
Not Found
The requested URL /mapserver/mapserv was not found on this server.
What could be wrong ?
Also I don’t know why it strip out the information I put in when up loading
the capabilities it displays
when I put in
Any ideas?
more detailed infos see below
Thanks
Karsten
In Mapbender admin I uploaded the wms and got this information – does that
look ok?
file:
http://localhost/mapserver/mapserv.exe?map=ok.map&REQUEST=GetCapabilities&SE
RVICE=WMS&VERSION=1.1.0
version: 1.1.0
title: ocla
abstract:
maprequest: http://localhost:81/mapserver/mapserv?map=ok.map&
capabilitiesrequest: http://localhost:81/mapserver/mapserv?map=ok.map&
featureinforequest: http://localhost:81/mapserver/mapserv?map=ok.map&
gui_wms_mapformat: image/png
gui_wms_featureinfoformat: text/plain
gui_wms_exceptionformat: application/vnd.ogc.se_inimage
gui_wms_epsg: EPSG:4326
wms_srs: epsg:4326
gui_wms_visible: 1
map -> image/gif
map -> image/png
map -> image/png; mode=24bit
map -> image/jpeg
map -> image/wbmp
map -> image/tiff
featureinfo -> text/plain
featureinfo -> application/vnd.ogc.gml
exception -> application/vnd.ogc.se_xml
exception -> application/vnd.ogc.se_inimage
exception -> application/vnd.ogc.se_blank
id: 1 parent: 0 name: People1 title: people queryable: 1 minScale: 0
maxScale: 0
dataurl:
metadataurl:
EPSG:4326
661172
-527873
2.63636e+006
751825
layerstyle:
name
title
legendurl
legendurlformat
default
default
http://localhost:81/mapserver/mapserv?map=ok.map&version=1.1.1&service=WMS&r
equest=GetLegendGraphic&layer=People1&format=image/png
image/png
And finally here is what I have in my map file:
# Start of map file
NAME "ocla"
EXTENT 600000 -800000 2750000 1000000
SIZE 400 400
UNITS FEET
IMAGECOLOR 204 221 255
IMAGETYPE PNG
INTERLACE OFF
#### Start of projection definition ###################
# NAD83 / Washington North (ftUS) EPSG <2285>
PROJECTION
                        "init=epsg:4326"
END
# Start of web interface definition##############################
WEB
  IMAGEPATH "D:/web/sites/mapserver/tmp/"
            METADATA
     # "wms_title" "terragis"
     "wms_onlineresource" "http://localhost:81/mapserver/mapserv?map=ok.map"
     "wms_srs" "epsg:4326"
            END
END
# Start of layer definitions##################################
LAYER
            NAME "People1"
            TYPE POLYGON
            DATA "D:/web/sites/mapserver/wsba/mapdata/layers/tracts"
     metadata
              "wms_srs"               "EPSG:4326"
        "wms_title"             "people"
        "wms_exceptions_format" "application/vnd.ogc.se_xml"
        "wms_server_version"    "1.1.1"
        "wms_formatlist"        "image/png"
        "wms_format"            "image/png"
     end
            dump true
PROJECTION
                        "init=epsg:4326"
END
            TEMPLATE "template"
            TOLERANCE 3
            STATUS ON
            CLASS
                        NAME "Up to 5"
                        EXPRESSION ([INSTITUTN] >= 0 AND [INSTITUTN] <= 5)
                        STYLE
                                    COLOR 112 153 89
                        END
            END
            CLASS
                        NAME "6 - 50"
                        EXPRESSION ([INSTITUTN] >= 5 AND [INSTITUTN] <= 50)
                        STYLE
                                    COLOR 178 194 141
                        END
            END
END
END # Map File
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20071212/bccae961/attachment-0001.html
More information about the Mapbender_users mailing list
