Re: AW: [Mapbender-users] Speicherung von digitalisierten Daten über Geoserver und Postgis
Christoph Baudson
christoph.baudson at wheregroup.com
Thu Jan 11 06:22:11 EST 2007
Hello Bruno,
thanks for your mail.
The problem lies within the architecture of Mapbender. In the current
release the server-side script geom2wfst.php tries to alert a Javascript
error message. This is not how it should be, but it worked, at least on
my configuration (Firefox). In the new release, the script will be
called via Ajax and the caller (mod_digitize_tab) will alert the error
message itself. This is a much more elegant approach.
In the meantime I suggest that you modify the script: (a) remove JS code
(b) add php exceptions when an error occurs. This would result in a more
robustness, but without success confirmation.
If you need help with the modification just let me know and I'll help.
Christoph
Bruno.Buechele at Landkreis-Ravensburg.de schrieb:
> Hello the next answer off my self
> i have now downgrade to version 1.3.3 of geoserver and changed the file "mod_digitize_tab.php". Now the data are stored in postgis. The next problem is, that i get the follow message from IE6 "'window.opener' ist Null oder kein Objekt from geom2wfst.php
> Best thanks, Bruno
> Hello Arnulf,
> i changed the file geom2wfst.php to control the data. In the "function sendToHost($host,$port,$method,$path,$data)" i added the lines "error_log(sprintf("sendtohost_wert: %s,%s,%s,%s",$host,$port,$method,$path));
> error_log(sprintf("data_wert: %s",$data));" and get the listet URL. The URL comes from file "mod_digitize_tab.php".
> I works with Geoserver 1.4.0 and this dont works fine. Should i downgrade to version 1.3.3 or 1.3.1?
> Best thanks, Bruno
> -----Ursprüngliche Nachricht-----
> Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Arnulf Christl
> Gesendet: Dienstag, 9. Januar 2007 17:47
> An: Mapbender Users Help each Other
> Betreff: Re: [Mapbender-users] Speicherung von digitalisierten Daten über Geoserver und Postgis
> Hi,
> the public GeoServer at wms1.ccgis.de is a version 1.3.1 and works fine.
> Where did you get this URL from:
> http://wms1.ccgis.de/geoserver-1.3-beta4/wfs/getCapabilities?request=describefeaturetype&typename=mapbender_user
> For me it returns a 404?!
> Additionally GeoServer 1.3.4 has a problem with updating objects that is planned to be fixed with version 1.4.2 (check their bug tracker).
> Rgards, Arnulf.
> Bruno.Buechele at Landkreis-Ravensburg.de wrote:
>> Hallo Liste,
>> ich denke es ist Zeit, dass ich Hilfe bei euch suche. Ich habe eine Postgis-Datenbank und habe diese auch schon in Geoserver geladen. Den Dienst habe ich dann in mapbender integriert und erhalte dann in meine Gui auch die Möglichkeit, Daten zu speichern. Allerdings kommen die Daten nicht in meiner Datenbank an. Ich habe mal die Daten die von geom2wfst.php geschrieben werden sollten in eine log-Datei geschrieben und erhalte folgenden log:
>> <wfs:Transaction version="1.0.0" service="WFS"
>> xmlns="http://www.someserver.com/myns"
>> xmlns:topp="http://www.openplans.org/topp"
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:xs="http://www.w3.org/2001/XMLSchema"
>> xmlns:ogc="http://www.opengis.net/ogc"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:wfs="http://www.opengis.net/wfs"
>> xsi:schemaLocation="http://www.someserver.com/myns
>> http://wms1.ccgis.de/geoserver-1.3-beta4/wfs/getCapabilities?request=describefeaturetype&typename=mapbender_user http://www.opengis.net/wfs../wfs/1.0.0/WFS-transaction.xsd">
>> <wfs:Insert>
>> <topp:baugesuche_2>
>> <the_geom>
>> <gml:MultiPolygon srsName="EPSG:31467">
>> <gml:polygonMember>
>> <gml:Polygon>
>> <gml:outerBoundaryIs>
>> <gml:LinearRing>
>> <gml:coordinates>3569310,5294270 3569230,5294480 3569600,5294530 3569690,5294360 3569310,5294270</gml:coordinates>
>> </gml:LinearRing>
>> </gml:outerBoundaryIs>
>> </gml:Polygon>
>> </gml:polygonMember>
>> </gml:MultiPolygon>
>> </the_geom>
>> </topp:baugesuche_2>
>> </wfs:Insert>
>> </wfs:Transaction>
>> das Problem datei ist offensichtlich folgender Eintrag:http://wms1.ccgis.de/geoserver-1.3-beta4/wfs/getCapabilities?request=describefeaturetype&typename=mapbender_user
>> wenn ich die selben Daten unter Geoserver mit "http://localhost:8080/geoserver/wfs/DescribeFeatureType?typename=topp:baugesuche_2">
>> sende, werden die Daten eingetragen.
>> Kann mir jemand sagen, wo ich das SchemaLocation richtig hinterlegen muss?
>> Grüße an alle von
>> Bruno Büchele
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
