[Mapbender-users] IE vs. Firefox - map repaint with the space bar
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Wed Jul 18 09:30:46 EDT 2007
Hi Juergen,
is your Mapbender online? I would like to take a look.
Cheers,
Christoph
Rogozia, Juergen schrieb:
> Hallo list!
> We are using mapbender 2.4.1 with some our own GUI, which is based on
> the original GUI2. Everything works fine with firefox (like most of the
> time) but with IE7 we discovered a strange event-behavior.
> We are using our own AJAX-streetsearch form. It listens to events in a
> form field and behaves like it should - with firefox. With the IE7 the
> form does not work. The reason (I think) is, that the IE7 is listening
> to a event which will do a repaint after pressing the space bar. Is
> there a way to switch that off?
> After I manually reload the AJAX-form everything works fine and for e.g.
> pressing the spacebar while filling out the form has no repaint-effect.
> Many thanks in advance
> Juergen
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:info at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Baudson Christoph
More information about the Mapbender_users
