Antw: Re: [Mapbender-users] MB 2.4.2 RC - gazetteerWFS
Christoph Ratke ratke at geoinformationsdienst.de
Fri Jul 20 08:57:38 EDT 2007
Helas all,
I am using the gazetteer as well and it is working fine - with Firefox.
Using IE I also have an empty iframe. The IE Error console tells me that
a "unbekannter Laufzeitfehler" (unknown runtime error?) in module
mod_wfs_gazetteer_client occurrs. In FF the javascript console is empty.
Does anybody have an idea?
@ Ronald: which browser(s) are you using?
Christoph Ratke
Am Freitag, den 20.07.2007, 10:34 +0200 schrieb Ronald Woita:
> Hi,
> The wfs_conf id is correctly inserted in the element_var 'wfsConfIdString' and there is'nt an error message in mapbender_log anymore, but the iframe is still blank.
> Looking at the following source text from my GUI I wonder about the line
> -->var targetString = 'mapframe1,overview';var wfsConfIdString = '';<--
> Why is'nt there a value for wfsConfIdString although the same string in comment is correct ?
> greetings
> Ronald
> <script type="text/javascript">
> var wfsConfIdString = '11';
> </script>
> <style id="wfsConfStyle" type="text/css"></style>
> var targetArray = targetString.split(",");
> var global_wfsConfObj;
> var global_selectedWfsConfId;
> var point_px = 10;
> var resultGeom = null;
> var cw_fillcolor = "#cc33cc";
> Ronald Woita
> http://geoportal.rostock.de
> Hansestadt Rostock
> Kataster-, Vermessungs- und Liegenschaftsamt
> Holbeinplatz 14, 18069 Rostock
> email: ronald.woita at rostock.de
> phone: +49 (0)381 - 381 6256
> >>> verena.diewald at wheregroup.com 19.07.2007 08:53 >>>
> Ronald Woita schrieb:
> > Hi all,
> > in previous version 2.4.1 I used the module '../php/mod_wfs_gazetteer.php'.
> > In version 2.4.2 this was replaced by '../javascripts/mod_wfs_gazetteer_client.php'.
> > I tried to configure it with the same WFS settings, but I get an empty iframe for the gazetteerWFS and this error message in log :
> > 2007.07.19, 07:59:44,Error while executing prepared statement in /srv/www/htdocs/mapbender/geoport_242/http/php/mod_wfs_gazetteer.php: Sql: SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2, Error: ERROR:  invalid input syntax for integer: ""
> > Are there any additional modules to load in the gui (excepting ajax)?
> > greetings
> > Ronald
> > Ronald Woita
> > Hansestadt Rostock
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Hi Ronald,
> as Mapbender uses now ajax for wfs gazetteer, wfs_conf IDs are now
> inserted comma separated in Element Var named "wfsConfIdString", not
> longer in src url. This could be the problem why you get the empty
> iframe. To get more information you can also have a look to Mapbender Wiki:
> http://www.mapbender.org/index.php/WFS_gazetteer#Element_vars
> Best regards
> Verena
Christoph Ratke
Geoinformationsdienst GmbH
Götzenbreite 10, 37124 Rosdorf
Geschäftsführer: Dirk Feise
HRB:3062, Amtsgericht Göttingen
Tel.:   ++49 551-7890420
Fax.:   ++49 551-7890429
Email: ratke at geoinformationsdienst.de
Web: http://www.geoinformationsdienst.de
More information about the Mapbender_users mailing list
