[Mapbender-users] Digitize functionality and its dependencies ...
Michael Schulz mschulz at webgis.de
Tue Jun 12 05:35:47 EDT 2007
I am having some troubles to get a digitizing gui to work (again ;-))
after removing several at first sight not related modules ... at the
moment, the digitizing works without problems, but the dragBasePoint
and addBasePoint buttons are not working. Someone has a hint which
module has the functionality that is now missing?
I had the same problem with module setSpatialRequest: the gui is
pretty cleaned of buttons that are not absolutly necessary, so I
removed the rectangle zoom button (selArea), for setSpatialRequest I
only wanted the query by rectangle button, but that is not working,
since this button depends on the rubber-band functionality of the
selArea module ...
Ok, thanks for any hints on the dragBasePoint problem ...
Cheers, Michael
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users mailing list
