[Mapbender-users] Re: Digitize functionality and its dependencies
Michael Schulz
mschulz at webgis.de
Tue Jun 12 07:29:58 EDT 2007
Ok, got it ...
I enabled the useUsemap option in element_vars of setSpatialRequest,
which caused the div of the usemap (z-index 100) to block the
underlying points of the digitizing module (z-index 80) to react on
the mouseover event.
HAND, Michael
2007/6/12, Michael Schulz <mschulz at webgis.de>:
> Hi,
> I am having some troubles to get a digitizing gui to work (again ;-))
> after removing several at first sight not related modules ... at the
> moment, the digitizing works without problems, but the dragBasePoint
> and addBasePoint buttons are not working. Someone has a hint which
> module has the functionality that is now missing?
> I had the same problem with module setSpatialRequest: the gui is
> pretty cleaned of buttons that are not absolutly necessary, so I
> removed the rectangle zoom button (selArea), for setSpatialRequest I
> only wanted the query by rectangle button, but that is not working,
> since this button depends on the rubber-band functionality of the
> selArea module ...
> Ok, thanks for any hints on the dragBasePoint problem ...
> Cheers, Michael
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> In den Weihermatten 66
> 79108 Freiburg
> Tel +49 (0)761 556959-5
> Fax +49 (0)761 556959-6
> http://www.webgis.de / http://www.zopecms.de
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_users
