[Mapbender-users] Projection problem
Stephan Holl stephan.holl at intevation.de
Thu Mar 8 14:39:35 EST 2007
Dear Mapbenderers,
I have set up MB 2.4 with PG/PGIS as DB. Starting the gui1 from the
original configuration the germany-map and the MP-users are shown as
intendet. But, changing the projection to 34369 (or any other
projection except 31467) does not show up an image.
I assue the transformation is somewhat faulty and the resulting
BBOX-Parameters are wrong. The follwing request is generated when
selecting EPSG:31469 from the menu:
BBOX contains 0,NaN,0,NaN.
The following are taken from the metadata-document:
before transformation
http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_
user.map&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=Mapbender_User,Mapb
ender_Names&STYLES=,&SRS=EPSG:31467&BBOX=2931821.5625,5248260,4262868.4375,6
100130&WIDTH=625&HEIGHT=400&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TR
UE&EXCEPTIONS=application/vnd.ogc.se_xml
After transformation:
ender_Names&STYLES=,&SRS=EPSG:31469&BBOX=0,NaN,0,NaN&WIDTH=625&HEIGHT=400&FO
RMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.
ogc.se_xml
Is this a known problem?
Best
	Stephan
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20070308/0ab4bc8b/signature.bin
More information about the Mapbender_users mailing list
