Re: [Mapbender-users] mapbender erster login nicht möglich
    Uli Rothstein (WhereGroup)
    uli.rothstein at wheregroup.com
    Wed May  9 06:20:19 EDT 2007
maybe the solution is to remove the empty line in your mapbender.conf (Line 152).
Or interchange the two lines:
require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
session_start();
in your mod_logout.php
regards
Uli
Lucas Beck schrieb:
> Now everything works but now I have another problem whose solution I
> could not find on the net... It seems to be a php-problem even though I
> did not change any of the php-files...
> Everytime when I log out, I receive the following message:
> *Warning*: session_start() [function.session-start
> <http://www.zambezi.ethz.ch/mapbender/php/function.session-start>]:
> Cannot send session cache limiter - headers already sent (output started
> at /etc/mapbender/conf/mapbender.conf:152) in
> */etc/mapbender/http/php/mod_logout.php* on line *22*
> *Warning*: Cannot modify header information - headers already sent by
> (output started at /etc/mapbender/conf/mapbender.conf:152) in
> */etc/mapbender/http/php/mod_logout.php* on line *32*
> */etc/mapbender/http/php/mod_logout.php* on line *38
> *However, everything else seems to work but even though it is a bit
> annoying... Does anyone have the solution?
> Greets
> Lucas
> Astrid Emde (WhereGroup) schrieb:
>> Hi lucas,
>> try this. go to the mapbender.cong file and set PREPAREDSTATEMENTS to
>> false
>> # perpared statements (PHP > 5.1.x, PostgreSQL > 7.4)
>> define("PREPAREDSTATEMENTS",false);
>> greetings astrid
>> santa.maria schrieb:
>>> Hö...
>>> Also ich bin hier auch ein wenig newbie, oder wie auch immer ihr dem
>>> sagt...
>>> wieauchimmer, ich habe einen server mit ubuntu, php5 psql 8.1.9
>>> inklusive
>>> postgis und bin nun am installieren des mapbender 2.4.1.
>>> nun, erst hatte ich ein paar probleme mit dem login und einiegen
>>> fehlermeldungen auf dem "mapbender_setup.php", habe dann aber unter
>>> anderem
>>> noch  in der pg_hba.conf alle wesentlichen stellen auf "trust"
>>> geändert und
>>> dann war in meinem "mapbender_setup.php" plötzlich alles ok.
>>> nun wollte ich mich als root mit passwort "root" einloggen, aber da
>>> kommt
>>> immer nur dieser login-screen wieder zum vorschein. bringt alles nichts.
>>> ich habe dann noch der tabelle  mb_user den login des root neu
>>> gesetzt und
>>> auch den zählerstand von mb_user_login_count auf 0 gesetzt.
>>> nun bin ich am ende meines lateins, habe keine ahnung was ich weiter
>>> machen
>>> soll...
>>> gruss
>>> lucas
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
