[Mapbender-users] Slightly OT: PostGIS Layer in UMN Mapserver
Jan Peters-Anders petersja at gmx.at
Sat May 12 13:34:16 EDT 2007
Hi Arnulf,
> Adding "&sessionId=***" as a paramater to your request should do the
> trick.
> But the whole setup is somewhat experimental, error prone and hard to
> debug. You should consider taking the customization of your request
> out of the database and into the client where it belongs. If you are
> using WMS this would be accomplished by adding OGC SLD or FE
> parameters. Then you do not need to modify your database but only the
> request.
> Regards, Arnulf
thanks for this advice. What I want to do is to query the database for a
list of companies that should then be displayed in the map. I am using
an application called msCross where the layers of the mapfile are
directly displayed. What I see is that it displays the layers of the
mapfile directly and does not send a WMS request (if I am right...). It
would be quite a long  request  string to ask for  e.g. 10 000 company
ids (btw: Is this possible at all?) or am I thinking in the wrong
direction here?
Regards
Jan
More information about the Mapbender_users mailing list
