[Mapbender-dev] Re: [Mapbender-users] Charset/coding problem:
broken Umlaute with MB 2.4.2
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Fri Nov 23 08:26:00 EST 2007
There also is a work group on encoding. Look what they have come up with
http://www.mapbender.org/index.php/Encoding_UTF8/ISO8859-1
But these bits of information are just pieces of a complex puzzle...
Christoph
Arnulf Christl schrieb:
> Tilo Wütherich wrote:
>> Hi Till,
>>> the quickest and easiest way is to force your webserver to give out
>>> any html from the mapbender-directory in iso 8859-1.
>> the output is ok, but it's the search for words (wfs_gazetteer) with
>> Umlaute that does not work.
>> Cheers,
>> Tilo
> Hi,
> the Umlaut-problem is somewhat more complex because it also depends on
> the encoding that has been defined for the WFS and the one defined for
> the database, data source or data store. The list of involved
> components can be quite long:
> * Browser (Encoding it can be set manually - even for each frame
> individually!)
> * Apache WebServer (overrides when no setting can be found in the HTML
> page header)
> * OGC Service
> ** MapServer (don't know)
> ** GeoServer (can be set globally in the configuration)
> * Database or Shapefile (individually)
> I tried to put this into a context here:
> This still needs to be worked over and extended!
> Make sure that you know which components are involved and the most
> important is:
> BE CONSISTENT!
> BE CONSISTENT!
> BE CONSISTENT!
> Best regards, Arnulf. _______________________________________________
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Where2B-Konferenz
Die Lösungskonferenz der WhereGroup
am 29. November 2007 in Bonn
http://www.where2b-conference.com
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
olaf.knopp at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
