[Mapbender-users] sel_area box hidden behind map images
Michael Schulz
mschulz at webgis.de
Tue Sep 18 17:21:46 EDT 2007
Hi Marc,
i was also looking through the different references on z-indexes and
finally came to the conclusion that the crucial point seems to be the
stacking context, that states that elements with z-indexes are stacked
in a context, in a way that if parent element has a z-index, and
child elements have z-indexes, the children stay inside the stacking
context and do not overlap with other stacking contexts. I then
checked mod_map1.php and found, that the parent map div has no z_index
defined, thus the map images inside it inherit the document stack
context and hence collide with other z-indexes. Simply adding a
z-index:2 at the map-div solved the problem. No other z-index had to
be touched.
I tried this first (changing only the z-indexes of the red lines), but
uh, suddenly the measure module was affected, not good.
Ok, die kurze deutsche Fassung: Elemente mit z-index im Style
definieren eine Stapel-Umgebung, die von eingeschlossenen Elementen
mit Z-Indizes nicht verlassen wird. Da in der mod_map1.php das
umgebende map-div kein z-index hat, erben die darin stehenden map-divs
die Stapel-Umgebung des kompletten Dokuments und können mit anderen
Elementen in der Stapelung kollidieren. Daher reicht es dem äusseren
map-div einen z-index:2 zu geben, dann ist das Problem gelöst.
Viele Grüße, Michael
Am 18.09.07 schrieb Marc Jansen <jansen.marc at gmx.de>:
> Hi Michael,
> an interesting question. As the W3C states, allowed values for z-index
> are -- beneath auto and inherit -- integers (even negative ones, see
> http://www.w3.org/TR/CSS21/syndata.html#value-def-integer). There is
> AFAIK no maximum value specified for the integer in the context as a
> value for z-index
> (http://www.w3.org/TR/CSS21/visuren.html#propdef-z-index). A quick
> Google search suggested a logical maximum value: 2147483647 seems to
> be the max allowed value (= max size of a signed 32bit integer, see
> http://www.webmasterworld.com/css/3171986.htm).
> I therefore guess that any value up to, say, 10000 should be ok. I don't
> know of any sideffects due to high values for z-index.
> If I wrote nonsense, please correct me ;-)
> eine interessante Frage.Laut W3C sind erlaubte Werte für z-index --
> neben auto und inherit -- Ganzzahlen, auch negative
> (http://www.w3.org/TR/CSS21/syndata.html#value-def-integer). Soweit ich
> weiß ist kein Maximalwert für den Kontext z-index spezifiziert
> (http://www.w3.org/TR/CSS21/visuren.html#propdef-z-index). Google hilft
> mit einer konkreteren Zahl: 2147483647 scheint ein Maximum zu sein (die
> Zahl ist der maximale werte einer vorzeichenbehaftetetn Ganzzahl auf
> 32bit Systemen, vgl.http://www.webmasterworld.com/css/3171986.htm).
> Daher sollten Werte bis, sagen wir, 10000 OK sein, schätze ich. Ich weiß
> von keinen Nebeneffekten, die durch hohe Z-Indizees verursacht werden.
> Sollte ich Unsinn geschrieben haben, bitte korrigieren ;-)
> -- Marc
> Michael Schulz schrieb:
> > Hi,
> > have you ever experienced the problem, that the red (or whatever color
> > you give it) zoom box outline is hidden behind some map images? I
> > noticed that when my gui apparently had too many wms services
> > assigned. So that the z-index of some maps is above the z-index of the
> > box outline.
> > I've changed the z-index of the zoom box, so that they were again on
> > top, but do you know of possible side-effects?
> > Cheers, Michael
> > hat jemand schonmal bemerkt, dass die rote Zoombox plötzlich hinter
> > einigen Kartenbildern liegt? Fiel mir auf, als mein GUI offensichtlich
> > zu viele wms dienste enthielt und damit der z-index der kartenbilder
> > den z-index der Linien roten Box überschritt.
> > Habe mal den z-index der Linien erhöht, dann sind sie wieder vorne.
> > Aber kann das irgendwelche Seiteneffekte haben?
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
+++ INTERGEO 25.09. - 27.09.07 Leipzig - Open Source Park, Halle 3,
Stand K3.302 +++
More information about the Mapbender_users
