AW: [Mapbender-users] Geoserver Default WFS Capabilities into Map bender
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Fri Sep 28 03:54:04 EDT 2007
Hello Martin,
could you send the Capabilities document of your wfs? So we could have a
look at it.
There was a problem when you have a line break in your abstract.
At the moment we have a problem with namespace see:
http://trac.osgeo.org/mapbender/ticket/92
Let's have a look at the xml to find the problem.
Greetings Astrid
Weißmann, Markus schrieb:
> Hello Roland!
> at WFS Conf the default WFS from Geoserver appear with "Compumatica
> Secure Networks - We secure YOUR business", but but there is not
> any layer to select or configure.
> Markus
>     *Von:* mapbender_users-bounces at lists.osgeo.org
>     [mailto:mapbender_users-bounces at lists.osgeo.org] *Im Auftrag von
>     *Roland Jehle
>     *Gesendet:* Freitag, 28. September 2007 09:09
>     *An:* 'Mapbender User List'
>     *Betreff:* AW: [Mapbender-users] Geoserver Default WFS
>     Capabilities into Mapbender
>     Hello Makus!
>     It is difficult for me to find out your problem, but with
>     Geoserver normally it works fine.
>     Try to find your WFS-Service in the WFS Conf.
>     If your upload was "ok" you find your WFS in this module and you
>     can configure it here for your WFS-Search or Digitize.
>     Lg
>     Roland
>     *"Weißmann, Markus"
>     *Gesendet:* Freitag, 28. September 2007 06:59
>     *An:* mapbender_users at lists.osgeo.org
>     *Betreff:* [Mapbender-users] Geoserver Default WFS Capabilities
>     into Mapbender
>     En:
>     Hello!
>     For a short time i have got the Geoserver running. The request
>     http://<server>:8080/geoserver/wfs?REQUEST=getCapabilities&VERSION=1.0.0&SERVICE=WFS
>     <http://%3cserver%3e:8080/geoserver/wfs?REQUEST=getCapabilities&VERSION=1.0.0&SERVICE=WFS>
>     work without any fault. I try to put it into the gui_digitize at
>     Mapbender with "Load WFS", but unfortunately it does not work.
>     There is no exception, but i don't see any content. Maybe only a
>     beginner fault. Does anybody know which one? Other WFS (UMN) work.
>     Hallo,
>     De:
>     Ich habe seit kurzem einen Geoserver am Laufen. Der Aufruf des
>     Default-WFS
>     funktioniert ohne Probleme. Versuche ich mit "WFS laden" ihn in
>     die gui_digitize von Mapbender zu laden, klappt es leider nicht.
>     Es gibt zwar keine Fehlermeldung, aber sehe auch keinen Inhalt.
>     Wahrscheinlich nur ein Anfängerfehler. Weiß  jemand welcher?
>     Andere WFS (UMN) funktionieren.
>     Mit freundlichem Gruß
>     Markus Weißmann
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 http://www.wheregroup.com
 Amtsgericht Bonn, HRA 6788
 Komplementärin:
 WhereGroup Verwaltungs GmbH
 vertreten durch:
 Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
