AW: [Mapbender-users] Geoserver Default WFS Capabilities into Map
bender
"Weißmann, Markus"
Markus.Weissmann at LGN.Niedersachsen.de
Fri Sep 28 04:51:52 EDT 2007
Hello Astrid, hello Roland,
thank you for your help but now i have found the fault: I took the url with
the servername and without the domain. When i take them both it works! But
Mapbender maybe should give an exception, shouldn't he?
By the way the envoking of the capabilities from my browser without the
domain was successfully.
Thanks
Markus
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [
<mailto:mapbender_users-bounces at lists.osgeo.org>
mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Astrid Emde
(WhereGroup)
Gesendet: Freitag, 28. September 2007 09:54
An: Mapbender User List
Betreff: Re: AW: [Mapbender-users] Geoserver Default WFS Capabilities into
Map bender
Hello Martin,
could you send the Capabilities document of your wfs? So we could have a
look at it.
There was a problem when you have a line break in your abstract.
At the moment we have a problem with namespace see:
<http://trac.osgeo.org/mapbender/ticket/92>
Let's have a look at the xml to find the problem.
Greetings Astrid
_____
[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Roland Jehle
Gesendet: Freitag, 28. September 2007 09:43
An: 'Mapbender User List'
Betreff: AW: [Mapbender-users] Geoserver Default WFS Capabilities into
Hello Markus!
Normally there are radiobuttons to select the layers after you selected the
WFS in a selectbox in WFS Conf.
You can also download an OS products like QGIS or Gaia to test your WFS with
another software.
You may have to define the featuretype in Geoserver first to see the layers
and don't forget to define the bounding box there.
Lg
Roland
_____
[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von "Weißmann,
Markus"
Gesendet: Freitag, 28. September 2007 09:34
Hello Roland!
at WFS Conf the default WFS from Geoserver appear with "Compumatica Secure
Networks - We secure YOUR business", but but there is not any layer to
select or configure.
Markus
_____
Gesendet: Freitag, 28. September 2007 09:09
Hello Makus!
It is difficult for me to find out your problem, but with Geoserver normally
it works fine.
Try to find your WFS-Service in the WFS Conf.
If your upload was "ok" you find your WFS in this module and you can
configure it here for your WFS-Search or Digitize.
Lg
Roland
_____
Markus"
Gesendet: Freitag, 28. September 2007 06:59
An: mapbender_users at lists.osgeo.org
Betreff: [Mapbender-users] Geoserver Default WFS Capabilities into Mapbender
En:
Hello!
For a short time i have got the Geoserver running. The request
<http://%3cserver%3e:8080/geoserver/wfs?REQUEST=getCapabilities&VERSION=1.0.
0&SERVICE=WFS>
http://<server>:8080/geoserver/wfs?REQUEST=getCapabilities&VERSION=1.0.0&SER
VICE=WFS work without any fault. I try to put it into the gui_digitize at
Mapbender with "Load WFS", but unfortunately it does not work. There is no
exception, but i don't see any content. Maybe only a beginner fault. Does
anybody know which one? Other WFS (UMN) work.
Hallo,
De:
Ich habe seit kurzem einen Geoserver am Laufen. Der Aufruf des Default-WFS
0&SERVICE=WFS>
VICE=WFS funktioniert ohne Probleme. Versuche ich mit "WFS laden" ihn in die
gui_digitize von Mapbender zu laden, klappt es leider nicht. Es gibt zwar
keine Fehlermeldung, aber sehe auch keinen Inhalt. Wahrscheinlich nur ein
Anfängerfehler. Weiß jemand welcher? Andere WFS (UMN) funktionieren.
Mit freundlichem Gruß
Markus Weißmann
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20070928/3259796b/attachment-0001.html
More information about the Mapbender_users
