[Mapbender-users] SLD Editor writes not working SLD URLs
Michael Schulz
mschulz at webgis.de
Fri Sep 28 05:34:01 EDT 2007
i assume you are using the sld-branch code? Calling the php-function
script is currently not implemented. At the moment one way would be to
save the generated sld in a file and reference it via an url in the
sld-url filed.
The way we are heading with the integration of the sld-url doesn't use
this php-call as a sld-url. We'd rather save a static sld file to the
file system, the url to this sld will be inserted in your sld-url
field in the gui-wms settings. A sld for a wms does not necessarily
need to come from the sld-editor, it could also be a provided as a
remote sld.
But we als also still discussing these issues and we are happy about
new input, either on the list (perhaps better on dev) or on the wiki
pages.
Cheers, Michael
2007/9/27, Roland Jehle <r.jehle at ceit.at>:
> Zers aus Ösi!
> I have integrated the SLD Editor into Mapbender 242.
> It seems that it works fine with the example WMS. I can edit the Layers SLD
> and save it.
> I can also see the saved changes in the SLD in table sld_user_layer.
> The SLD with URL
> (http://.........../sld/sld_function_handler.php?function=getusersld&layer_id=19009&user_id=1)
> which is at the end of the URL of the getMap-request seems to be right and
> gives the SLD-XML back when I insert it in the browser (e.g."Bundeslaender
> 1.000000 7000000.000000 #ffffff #2f4f4f admin_name arial 2 0.5 0.5 #000000
> Bundesländer 7000000.000000 80000000.000000 #000000 #2f4f4f admin_name 0.5
> 0.5 #000000") and the XML is in the source.
> I can't find out what is the problem with my SLD-URL, but it doesn't work in
> connection with the getMap requests although it seems to be fine.
> Lg
> Roland
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
+++ INTERGEO 25.09. - 27.09.07 Leipzig - Open Source Park, Halle 3,
Stand K3.302 +++
More information about the Mapbender_users
