[Mapbender-users] resizeMapsize: suggest for improvement
Arnulf Christl
arnulf.christl at wheregroup.com
Sun Apr 13 15:16:58 EDT 2008
On Tue, April 8, 2008 09:46, Christoph Baudson wrote:
> Arnulf Christl schrieb:
>> Hello, this sounds like a good change request. I created a ticket.
>> Please check whether I got this right:
>> http://trac.osgeo.org/mapbender/ticket/206
>> Lets see whether they will squeeze it into 2.5, at least we can try.
> Take a look at http://trac.osgeo.org/mapbender/ticket/206
> I guess it is fixed now. Hope I got what you meant.
>From what I can tell it works fine, thanks a lot.
Arnulf.
>> Best regards, Arnulf.
>> Schönhammer, Herbert wrote:
>>> Hallo Liste,
>>> beim Start einer MapBender -gui werden die default-Dienste sofort
>>> geladen.
>>> Bei Einsatz des Modules reizeMapsize wird erst anschließend die
>>> mapframe1 - Größe verändert.
>>> Die default-Dienste werden erneut geladen. Dies ist aus Gründen der
>>> Performance sowie der Server-Last natürlich nicht sehr schön.
>>> Kann man das ändern ? (Evtl. Verbesserungsvorschlag noch für die neue
>>> MapBender-Version ?)
>>> Grüße Schönhammer Herbert
>>> Hi list,
>>> starting a mapbender gui, mapframe1 is requesting the needed (default)
>>> WMS.
>>> resizeMapsize (mod_resize_mapsize.php) is changing the size of the
>>> mapframe1 afterwards.
>>> So (a) new request(s) are done.
>>> Is it possible to alter resizeMapsize, so that the initial
>>> WMS-requests are done after resizing the mapframe 1 ??
>>> greetings
>>> Schönhammer Herbert
>>> _______________________________________________ Mapbender_users
>>> mailing list Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Mapbender_users mailing list
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 25
> Fax: +49 (0)228 / 90 90 38 - 11
> christoph.baudson at wheregroup.com www.wheregroup.com Amtsgericht Bonn, HRA
> 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch: Arnulf Christl, Olaf Knopp, Peter Stamm
Arnulf Christl
http://www.wheregroup.com
More information about the Mapbender_users
