[Mapbender-users] problems at creating mapbender2.5 schema
Michael Schulz mschulz at webgis.de
Thu Apr 17 12:04:06 EDT 2008
Hi Marc,
the mapbender database must have the plpgsql language installed,
because of the i18n functions. If your db has plpgsql already
installed, then you can comment this statement from the schema.sql.
We should have look for a "check if exists" way to do this, because a
lot of people will have plpgsql installed (e.g. from postgis).
Cheers, Michael
2008/4/17 Marec <marec at t-online.de>:
> Hi list,
>  i actually downloaded  the new mapbender(2.5rc1) release.
>  Now i have a problem at creating the new Database schema.
>  If  i execute the "pgsql_schema.sql" i get following error message:
>  ERROR:  language "plpgsql" already exists
>  Is the first statement a mandatory setting in the new release or can i
> delete it??
>  Because I couldn't find the first statemets in older releases.
>  greetings Marc
>  _______________________________________________
>  Mapbender_users mailing list
>  Mapbender_users at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users mailing list
