[Mapbender-users] problems at creating mapbender2.5 schema
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Apr 18 04:28:56 EDT 2008
Michael Schulz schrieb:
> Hi Marc,
> the mapbender database must have the plpgsql language installed,
> because of the i18n functions. If your db has plpgsql already
> installed, then you can comment this statement from the schema.sql.
> We should have look for a "check if exists" way to do this, because a
> lot of people will have plpgsql installed (e.g. from postgis).
As it is listed in the installation guide in
http://www.mapbender.org/Installation_en#PostgreSQL_database
I have removed these two lines from the schema SQL.
Download:
https://svn.osgeo.org/mapbender/branches/2.5/resources/db/postgresql/pgsql_schema.sql
Da dies schon in den Installationsanweisungen aufgelistet wurde, siehe
http://www.mapbender.org/Installation_de#PostgreSQL_Datenbank
habe ich die beiden Zeilen aus dem Schema SQL entfernt.
Download:
> Cheers, Michael
> 2008/4/17 Marec <marec at t-online.de>:
>> Hi list,
>> i actually downloaded the new mapbender(2.5rc1) release.
>> Now i have a problem at creating the new Database schema.
>> If i execute the "pgsql_schema.sql" i get following error message:
>> ERROR: language "plpgsql" already exists
>> Is the first statement a mandatory setting in the new release or can i
>> delete it??
>> Because I couldn't find the first statemets in older releases.
>> greetings Marc
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
