[Mapbender-users] error in sql statement pgsql_data.sql
Marec
marec at t-online.de
Thu Apr 17 12:24:31 EDT 2008
Hi list
I noticed another error in the installation of mapbender2.5rc1
if you want to fill your mapbender database with elements by using
"pgsql_data.sql".
You runs through an error
ERROR: duplicate key violates unique constraint "translations_pkey"
the reason for this is the new table translations!
In this sql statement the table is filled from line 8205
see here:
INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (1,
'de', 'Pan', 'Ausschnitt verschieben');
INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (2,
'de', 'Display complete map', 'gesamte Karte anzeigen');
INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (3,
'de', 'Zoom in', 'In die Karte hineinzoomen');
after this inserts, the same will execute from line 23011
INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan',
INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Display
INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom
out', 'Aus der Karte herauszoomen');
If you want to execute your sql correctly just edit this file and delete
the statements from line
8202-8255
and your sql will execute correctly
greetings Marc
More information about the Mapbender_users
