[Mapbender-users] error in sql statement pgsql_data.sql
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Apr 18 04:20:22 EDT 2008
Thanks Marec, I have removed the lines from the dump.
The new file is in the SVN and will be part of rc2.
https://svn.osgeo.org/mapbender/branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql
Die korrigierte Datei wurde eingecheckt und wird Teil von rc2 sein.
Christoph
Marec schrieb:
> Hi list
> I noticed another error in the installation of mapbender2.5rc1
> if you want to fill your mapbender database with elements by using
> "pgsql_data.sql".
> You runs through an error
> ERROR: duplicate key violates unique constraint "translations_pkey"
> the reason for this is the new table translations!
> In this sql statement the table is filled from line 8205
> see here:
> INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (1,
> 'de', 'Pan', 'Ausschnitt verschieben');
> INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (2,
> 'de', 'Display complete map', 'gesamte Karte anzeigen');
> INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (3,
> 'de', 'Zoom in', 'In die Karte hineinzoomen');
> after this inserts, the same will execute from line 23011
> INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan',
> INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom
> out', 'Aus der Karte herauszoomen');
> If you want to execute your sql correctly just edit this file and delete
> the statements from line
> 8202-8255
> and your sql will execute correctly
> greetings Marc
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
