Antw: [Mapbender-users] MB 2.5: capabilities-upload does not
work
Ronald Woita
Ronald.Woita at rostock.de
Thu Apr 24 07:06:07 EDT 2008
Hi Tilo,
i got the same problem and i had to run the script
pgsql_set_Serial_sequences.sql first
before i could start loading a wms in the 'fresh' database.
Ronald
>>> tilo.wuetherich at la-bw.de 24.04.2008 13:00:02 >>>
Hi All,
I'm testing MB 2.5rc2 and have some problems with uploading
wms-capabilities
documents. Some docs are partially hand-edited. You can see the calls
and
Mapbender returns as below.
Does anybody know some help?
Thanks,
Tilo
http://www.lv-bw.de/dv/capabilities-esri-testuser.xml
returns:
file: http://www.lv-bw.de/dv/capabilities-esri-testuser.xmlsql error:
ERROR:
duplicate key violates unique constraint "pk_gui_layer" ROLLBACK
performed....
http://<a_local_ip>:8080/geoserver/geoserver.xml
returns:
Missing parameters:
id:
version: 1.1.1
title: VM Jupiter GeoServer KlosterDB
abstract: This is a description of your Web Map Server.
maprequest:
capabilitiesrequest:
featureinforequest:
gui_wms_mapformat:
gui_wms_featureinfoformat:
gui_wms_exceptionformat:
gui_wms_epsg:
wms_srs:
gui_wms_visible: 1
gui_wms_opacity: 100
support_sld: 0
id: parent: name: title: queryable: 0 minScale: 0 maxScale: 0
dataurl:
metadataurl:
layerstyle:
name title legendurl legendurlformat
Data not commited
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
