Antw: [Mapbender-users] MB 2.5: capabilities-upload does notwork
    Tilo Wutherich
    tilo.wuetherich at la-bw.de
    Thu Apr 24 07:28:32 EDT 2008
Hi Ronald,
> i got the same problem and i had to run the script
> pgsql_set_Serial_sequences.sql first
> before i could start loading a wms in the 'fresh' database.
thank you, that's it! I run it accidentally before inserting the data-sql...
But the problem with the geoserver cap-doc remains. It works with MB 2.4.2
and I remember I didn't update to 2.4.3 because I could not make it work.
Cheers,
Tilo
> http://<a_local_ip>:8080/geoserver/geoserver.xml
> returns:
> Missing parameters:
> id:
> version: 1.1.1
> title: VM Jupiter GeoServer KlosterDB
> abstract: This is a description of your Web Map Server.
> maprequest:
> capabilitiesrequest:
> featureinforequest:
> gui_wms_mapformat:
> gui_wms_featureinfoformat:
> gui_wms_exceptionformat:
> gui_wms_epsg:
> wms_srs:
> gui_wms_visible: 1
> gui_wms_opacity: 100
> support_sld: 0
> id: parent: name: title: queryable: 0 minScale: 0 maxScale: 0
> dataurl:
> metadataurl:
> layerstyle:
> name	title	legendurl	legendurlformat
> Data not commited
More information about the Mapbender_users
