[Mapbender-users] Install Mapbender in Xampplite
Karsten Vennemann
karsten at TERRAGIS.NET
Sat Apr 26 13:22:04 EDT 2008
Sorry I don't anything about Xampplite, but from what you wrote it appears
that you are trying to install Mapbender with MySQL as a management
database. Thus you first have to install the MySql database software ( e.g.
download from http://dev.mysql.com/downloads/mysql/5.0.html#downloads the
"community server version) and create the actual mapbender administration
database. To do this you have to open the mysql command prompt or use the
Mysql management tool and enter the commands you mentioned typing:
CREATE DATABASE mapbender DEFAULT CHARACTER SET utf8 COLLATE utf8_bin;
the next step is to tell the system that the following command are to be
isued within the mapbender database :
use mapbender
Since you are new to most of this consider whether you would like to use
postgresql database software instead (download from
http://www.postgresql.org/download/ ) since to have additional spatial
functionality that at this point is not available using Mysql . Among those
unctions is e.g. the measure functionality used in mapbender along things
usch a spatial queries , overlay operation and much more available through
the Postgresql extention Postgis (download from
http://postgis.refractions.net/download/ )
Cheers
Karsten
Regine Weber wrote:
> Hello Everybody,
> my problem is in Installing Mapbender. I followed the instructions at
> http://www.mapbender.org/index.php/Installation_de
> But I don't know what to do at this point:
> and also at this point:
> use mapbender
> Where do I have to type this?
> Thank you very much for your help.
> One thing I want to say: I'm new to this all - WebServers, Programming and
> Mapbender. That's why I ask such simple questions.
> Best regards,
> Regine
> Ist Ihr Browser Vista-kompatibel? Jetzt die neuesten
> Browser-Versionen downloaden: http://www.gmx.net/de/go/browser
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
View this message in context: http://www.nabble.com/Install-Mapbender-in-Xampplite-tp16911095p16915304.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users
