Antw: [Mapbender-users] php with Option "--with-mm" needed for mapbender use ?
Ronald Woita Ronald.Woita at rostock.de
Tue Apr 29 06:50:23 EDT 2008
Hello Mr. Schoenhammer,
these are the options I installed php-5.2.5 on our SLES 10 Server :
./configure *prefix=/usr/local/php-5.2.x --with-zlib --with-gd=/usr/local --with-pgsql=/usr/local/pgsql/bin/pg_config --with-openssl *with-curl *enable-mbstring *with-gettext *with-apxs2=/usr/sbin/apxs2 --with-regex=system *enable-simplexml *enable-xml
Don't know really what the option '--with-mm' effects, but finally Mapbender does what it has to do :-)
regards
Ronald
>>> Schoenhammer.Herbert at Regensburg.de 28.04.2008 11:14:54 >>>
Hi List,
I don' get php5 running with configured option "--with-mm".
I really don't understand the php5-docs:
"Session support is enabled in PHP by default. If you would not like to build your PHP with session support, you should specify the --disable-session option to configure. To use shared memory allocation (mm) for session storage configure PHP --with-mm[=DIR] . "
So my question:
1) Is this php-option "--with-mm" needed for use with mapbender ?
2) Perhaps, if a "secure"-server (https, ows-security-proxy, ...) should be created ?
Background:
I must setup a new mapbender-Server. This Server must use SLES 10 and support mapbender, postgresql/postgis and oracle (via oci with mapserver and php5).
I had some troubles configuring and compiling all needed stuff.
I was not able to get SLES10-php5 working with Oracle-OCI.
Using the oracle-Zend-stuff, Oracle was working well, but I was not able to get the needed "--with-mbstring" (or Zend_Translate) working.
So I downloaded php 5.2.5 from www.php.net and compiled from scratch. But using --with-mm I get an error message when starting apache (no configue-error and no compiling error).
MapBender 2.5rc1 seems to work without "--with-mm", postgres/postgis is working, oracle is working.
I would be glad, if somebody could tell me, whether this option really is not needed for mapbender-use  !
greetings
Herbert Schoenhammer
More information about the Mapbender_users mailing list
