[Mapbender-users] admin:updateWFS
Ronald Woita Ronald.Woita at rostock.de
Mon Aug 18 06:50:51 EDT 2008
hi list,
after installing the release candidate no. 6 of the major version 2.5 I
tried
to update an existing WFS and then make a new Configuration :
The Update works fine and the new featuretypes are correctly put in the
according tables  but I can't make a WFS configuration.
This is the error message from log :
2008.08.18, 12:26:30,ERROR: array params and array types have a
different count  in
/srv/www/htdocs/mapbender_25/http/php/mod_wfs_conf.php: Sql: INSERT INTO
wfs_conf_element
(fkey_wfs_conf_id,f_id,f_search,f_pos,f_style_id,f_toupper,f_label,f_label_id,f_show,f_respos,f_edit,f_form_element_html,f_mandatory,f_auth_varname,f_show_detail)
VALUES($1, $2, '0', $3, $4, '0',$5, $6, '0', $7, '0',$8, '0',$9,'0');
2008.08.18, 12:26:30,ERROR: Error while executing prepared statement in
wfs_conf_element
VALUES($1, $2, '0', $3, $4, '0',$5, $6, '0', $7, '0',$8, '0',$9,'0'); ,
Error: ERROR:  bind message supplies 6 parameters, but prepared
statement "" requires 9
Does anybody get a hint what this message means ?
thanks
Ronald
More information about the Mapbender_users mailing list
