[Spam:medium] AW: [Mapbender-users] admin:updateWFS
Manns, Marc
manns at str.de
Wed Aug 20 02:42:47 EDT 2008
I've had a similar error message
at an earlier Version.
In my case it was an not completed mapbender installation.
I've forgotten to insert the files:
pgsql_serial_set_sequences.sql
pgsql_serial_set_sequences_7x.sql
to the Database.
Greetings Marc
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org
[mailto:mapbender_users-bounces at lists.osgeo.org]Im Auftrag von Ronald
Woita
Gesendet: Montag, 18. August 2008 12:51
An: mapbender_users at lists.osgeo.org
Betreff: [Mapbender-users] admin:updateWFS
hi list,
after installing the release candidate no. 6 of the major version 2.5 I
tried
to update an existing WFS and then make a new Configuration :
The Update works fine and the new featuretypes are correctly put in the
according tables but I can't make a WFS configuration.
This is the error message from log :
2008.08.18, 12:26:30,ERROR: array params and array types have a
different count in
/srv/www/htdocs/mapbender_25/http/php/mod_wfs_conf.php: Sql: INSERT INTO
wfs_conf_element
(fkey_wfs_conf_id,f_id,f_search,f_pos,f_style_id,f_toupper,f_label,f_label_id,f_show,f_respos,f_edit,f_form_element_html,f_mandatory,f_auth_varname,f_show_detail)
VALUES($1, $2, '0', $3, $4, '0',$5, $6, '0', $7, '0',$8, '0',$9,'0');
2008.08.18, 12:26:30,ERROR: Error while executing prepared statement in
wfs_conf_element
VALUES($1, $2, '0', $3, $4, '0',$5, $6, '0', $7, '0',$8, '0',$9,'0'); ,
Error: ERROR: bind message supplies 6 parameters, but prepared
statement "" requires 9
Does anybody get a hint what this message means ?
thanks
Ronald
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
