[Mapbender-users] WFS configuration: how to access global values?
Christoph Baudson christoph.baudson at wheregroup.com
Tue Dec 2 05:31:11 EST 2008
Michael Schulz schrieb:
> Hi,
> how would it be possible to use the values of some global variables
> (mb_user_name and the like) in the context of a wfs configuration? In
> my special case, we want the mb_user_name to be inserted when saving a
> digitized geometry. The featuretype has an attribute that should be
> filled with mb_user_name, without exposing an input element. Do you
> have any ideas how to do that?
> I thought about using a hidden input element and some JS to insert the
> value, but I didn't succeed.
There is a column in wfs_conf, "f_auth_varname". You can enter a php
variable like
$_SESSION['mb_user_name']
(use single quotes) for the appropriate feature type which will hold the
value of this variable.
This has been introduced in Mapbender 2.4.5, but there have been a lot
of bug fixes since then, so I recommend updating to 2.5
Christoph
> Any ideas?
> Cheers, Michael
Where2B-Konferenz
Die Geo-IT Konferenz der WhereGroup
vom 9.-10. Dezember 2008 in Bonn
Web: www.where2b-conference.com
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
