[Mapbender-users] MB 2.5: no load of wfs generated by mapserver 5.xx.x possible
Michael Schulz mschulz at webgis.de
Fri Dec 5 07:27:56 EST 2008
- are the featuretype attributes present in the capabilities document
at all of your mapserver 5.x service?
- did you set "wfs_include_items" "all" in your layer metadata?
I am sure that mb 2.5 can load successfully mapserver 5.0.2 wfs
services. I am using it without problems as a wfs-gazetteer.
Cheers,
Michael Schulz
2008/12/5 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
> Hi list,
> I only want to load a wfs into a gui. But this is not possible under all
> circumstances with MB version 2.5.
> If the wfs is generated by mapserver version 4.xx.x the wfs is loaded and
> all attributes of the wfs are listed. Output is:
> version: 1.0.0
> title: Bodenrichtwertgebiete
> abstract: Stadt Regensburg: Suche nach Bodenrichtwertgebieten
> capabilitiesrequest:
> http://geoportal/cgi-bin/getows?map=/cityportal-maps/rgb_wfs_bodenrichtwerte.map&
> describefeaturetype:
> getfeature:
> transaction:
>   _____
> title: Richtwertgebiete zum Stichtag 31.12.2006
> abstract:
> srs: epsg:31468
> element: msGeometry - GeometryPropertyType
> element: oid - string
> element: gebiet - string
> element: stichtag - string
> element: name_such_string - string
> namespace: ms - http://mapserver.gis.umn.edu/mapserver
> namespace: ogc - http://www.opengis.net/ogc
> namespace: xsd - http://www.w3.org/2001/XMLSchema
> namespace: xmlns - http://www.w3.org/2001/XMLSchema
> namespace: gml - http://www.opengis.net/gml
> If the wfs is generated by mapsverer version 5.xx.x ( I have testes 5.0.2
> and 5.2.0) the wfs is not loaded correctly by mapbender. The wfs has no
> attributes:
> version: 1.0.0
> title: Adressen in Regensburg
> abstract: Adressen im Stadtgebiet Regensburg
> http://secure1.regensburg.de/cgi-bin/mapserv-502?map=/data-umn/wfs/rgb_wfs_adressen.map&
> getfeature:
> transaction:
>   _____
> abstract:
> srs: EPSG:31468
> I wnat to use mapserver 5.x.x. Has anybody a tipp for me ?
> greetings
> Herbert Schoenhammer
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
