AW: [Mapbender-users] MB 2.5: no load of wfs generated by mapserver
5.xx.x possible
Schönhammer, Herbert
Schoenhammer.Herbert at Regensburg.de
Fri Dec 5 08:09:02 EST 2008
Hi Michael,
it's no good idea writing help messages after looking for the error for some time ;-)
So I just found the error in the select-statement of the DATA-clause (clarifying your tipps).
WFS generated of mapserver 5.xx.x are also working with MapBender.
Thanks for your reply.
By the way:
In the meantime I installed geoserver 1.7.0 and added the required wfs as a geoserver wfs. Do you know a possibility of sorting the result of a geoserver wfs ?
Thanks
Herbert Schoenhammer
und einen schönen Nikolaus-Abend alle miteinander !!
>-----Ursprüngliche Nachricht-----
>Von: mapbender_users-bounces at lists.osgeo.org
>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>von Michael Schulz
>Gesendet: Freitag, 5. Dezember 2008 13:28
>An: Mapbender User List
>Betreff: Re: [Mapbender-users] MB 2.5: no load of wfs
>generated by mapserver 5.xx.x possible
>Hi,
>- are the featuretype attributes present in the capabilities document
>at all of your mapserver 5.x service?
>- did you set "wfs_include_items" "all" in your layer metadata?
>I am sure that mb 2.5 can load successfully mapserver 5.0.2 wfs
>services. I am using it without problems as a wfs-gazetteer.
>Cheers,
>Michael Schulz
>2008/12/5 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
>> Hi list,
>> I only want to load a wfs into a gui. But this is not
>possible under all
>> circumstances with MB version 2.5.
>> If the wfs is generated by mapserver version 4.xx.x the wfs
>is loaded and
>> all attributes of the wfs are listed. Output is:
>> version: 1.0.0
>> title: Bodenrichtwertgebiete
>> abstract: Stadt Regensburg: Suche nach Bodenrichtwertgebieten
>> capabilitiesrequest:
>http://geoportal/cgi-bin/getows?map=/cityportal-maps/rgb_wfs_bo
denrichtwerte.map&
>> describefeaturetype:
denrichtwerte.map&
>> getfeature:
denrichtwerte.map&
>> transaction:
>> _____
>> title: Richtwertgebiete zum Stichtag 31.12.2006
>> abstract:
>> srs: epsg:31468
>> element: msGeometry - GeometryPropertyType
>> element: oid - string
>> element: gebiet - string
>> element: stichtag - string
>> element: name_such_string - string
>> namespace: ms - http://mapserver.gis.umn.edu/mapserver
>> namespace: ogc - http://www.opengis.net/ogc
>> namespace: xsd - http://www.w3.org/2001/XMLSchema
>> namespace: xmlns - http://www.w3.org/2001/XMLSchema
>> namespace: gml - http://www.opengis.net/gml
>> If the wfs is generated by mapsverer version 5.xx.x ( I have
>testes 5.0.2
>> and 5.2.0) the wfs is not loaded correctly by mapbender. The
>wfs has no
>> attributes:
>> version: 1.0.0
>> title: Adressen in Regensburg
>> abstract: Adressen im Stadtgebiet Regensburg
>http://secure1.regensburg.de/cgi-bin/mapserv-502?map=/data-umn/
>wfs/rgb_wfs_adressen.map&
>> getfeature:
>> transaction:
>> _____
>> abstract:
>> srs: EPSG:31468
>> I wnat to use mapserver 5.x.x. Has anybody a tipp for me ?
>> greetings
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>Michael Schulz
>mschulz at webgis.de
>in medias res
>Gesellschaft für Informationstechnologie mbH
>In den Weihermatten 66
>79108 Freiburg
>Tel +49 (0)761 556959-5
>Fax +49 (0)761 556959-6
>http://www.webgis.de / http://www.zopecms.de
>Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users
