AW: [Mapbender-users] Symbology-Problem
birger.heinss at vattenfall.de birger.heinss at vattenfall.de
Wed Dec 10 12:35:01 EST 2008
Thanks Karsten for response,
The problem isn't fixed by a fix offset. The offset amount should be the same for every realization auf this point feature, but the direction isn't. And that's the problem indeed.
Imagine the points are located at the end of line features or the touch a line feature. So the symbols edge should come together i.e start with the lines end or the lines segments.  If the symbols centre position works as the placement it looks wrong.
So one way would be to calculate the "right" position to place the symbol. But in that case the position would depend on the symbols size ...
Are there any ideas left??
cheers
Birger Heinß
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Karsten Vennemann
Gesendet: Mittwoch, 10. Dezember 2008 18:18
An: Mapbender_users at lists.osgeo.org
Betreff: Re: [Mapbender-users] Symbology-Problem
Hi there,
I am assuming you are using MapServer and a map file :) . Unfortunately I couldn't see the examples you tried to post, those are stripped off in mailing list postings (next time you can try putting them on a web server and just quote the URLs in your post...) So I might be off with the following suggestion but (since I couldn't see the examples ) but you can use the MapServer OFFSET tag (inside your layer style) to determine the location of your symbol in relation the the real word coordinates: OFFSET [x][y] e.g.
STYLE
	SYMBOL "POINT"
	SIZE 16
	COLOR 0 0 0
	OFFSET -16 0
END
see at http://umn.mapserver.ch/MapServer/en/style.htm
Cheers
Karsten
birger.heinss wrote:
> Hi List,
> how can I prepare a point symbol in such a way, that its placement
> coordinate is located at a definite position (for instance at the
> bottom of the symbol and not in the centre). We need a combinations of
> type "ellipse" and "vector".
> regular version:
> needed version:
> The cross illustrates the placement point.
> thanks a lot. best regards
> birger
> =# Vattenfall Europe Information Services GmbH, Hamburg, Amtsgericht
> Hamburg
> - HRB 86516
> Vorsitzender des Aufsichtsrates: Dr. Hans-Jürgen Meyer
> Geschäftsführer: Dr. Stefan Keese, Ernst Wudtke
> Diese E-Mail wurde digital signiert.
> Sie koennen anhand der Signatur nachvollziehen, dass die E-Mail
> wirklich von Vattenfall stammt und dass deren Inhalt auf dem
> Transportweg nicht manipuliert wurde. Weitere Informationen ueber die
> eingesetzten Signaturen finden Sie auf unserer Website unter
> http://www.vattenfall.de/pki.
> Mapbender_users mailing list
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
View this message in context: http://www.nabble.com/Symbology-Problem-tp20935785p20939766.html
Sent from the mapbender-users mailing list archive at Nabble.com.
Vattenfall Europe Information Services GmbH, Hamburg, Amtsgericht Hamburg - HRB 86516
Sie koennen anhand der Signatur nachvollziehen, dass die E-Mail wirklich von
Vattenfall stammt und dass deren Inhalt auf dem Transportweg nicht manipuliert
wurde. Weitere Informationen ueber die eingesetzten Signaturen finden Sie auf
unserer Website unter http://www.vattenfall.de/pki.
Type: application/x-pkcs7-signature
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20081210/89854103/smime.bin
More information about the Mapbender_users mailing list
