[Mapbender-users] Neue Version - andere BBox
Arnulf Christl
arnulf.christl at wheregroup.com
Fri Feb 1 10:44:26 EST 2008
Sascha Bahl wrote:
> Hello again!
> There is a bug in the module mod_dynamicOverview.php. I have copied the
> gui2, remove all wms and add my own. For Example a map for RLP:
> http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv4102.fcgi?map=/data/umn/navigation_atkis_ldi.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
> The requested parameters for bbox are wrong, but only in the version
> 2.4.4. The difference between the version 2.4 and 2.4.4. is apparently
> the module dynamicOverview, which is enable by default. If this module
> is disabled, than the requested bbox parameter are right.
> Cu
> Sascha Bahl
did you get any answer?
You must check the element_var value bbox of the dynamic overview map. You can specify which are the start parameters.
Regards, Arnulf.
More information about the Mapbender_users
