[Mapbender-users] Is button "center1" configurable?
Christoph Baudson christoph.baudson at wheregroup.com
Thu Feb 21 10:37:33 EST 2008
Tilo Wütherich schrieb:
> Hi Christoph,
>> That's true. If you want to make it fool-proof, add an element var, so
>> that you can set the zoom factor via the administration interface.
> thank you, it works "fool-proof" now :-)  It was a bit tricky to find the
> right entry for the field "target" in toggleModule - a hint in the docu
> would help.
feel free to edit. Do you have a Wiki account?
Cheers
Christoph
> Greetings,
> Tilo
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
