[Mapbender-users] Is button "center1" configurable?
Tilo Wütherich tilo.wuetherich at la-bw.de
Thu Feb 21 10:32:34 EST 2008
Hi Christoph,
> That's true. If you want to make it fool-proof, add an element var, so
> that you can set the zoom factor via the administration interface.
thank you, it works "fool-proof" now :-)  It was a bit tricky to find the
right entry for the field "target" in toggleModule - a hint in the docu
would help.
Greetings,
Tilo
More information about the Mapbender_users mailing list
