[Mapbender-users] Javascript error mb_execloadWmcSubFunctions
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Tue Jan 8 04:13:17 EST 2008
David,
which Mapbender version are you using?
Most likely a synchronisation issue, you might have to change the
position of some modules...maybe increase loadwmc's position in "edit
GUI elements" in the admin GUI and see; it should be loaded after the
wms modules I guess.
I have never tested this feature with an uncustomized Mapbender, so it
might not be stable.
Thanks
Christoph
David Arndt schrieb:
> Hello,
> I get a javascript error when I load a WMC from session:
> mb_execloadWmcSubFunctions is not defined
> Where can I find this function, maybe there is a typing error?
> Regards, David Arndt.
> geoinformation+planung
> reichert+partner ingenieure
> gölzstr. 22 72072 tübingen
> fon: +49 (0)7071-407360
> fax: +49 (0)7071-407361
> arndt at geoinformation-planung.de
> geoinformation+planung - reichert+partner |
> http://www.geoinformation-planung.de
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
