[Mapbender-users] Javascript error mb_execloadWmcSubFunctions
David Arndt
arndt at geoinformation-planung.de
Tue Jan 8 04:52:20 EST 2008
It is Mapbender 2.4.4
Thanks, David Arndt.Quoting "Christoph Baudson (WhereGroup)"
<christoph.baudson at wheregroup.com>:
> David,
> which Mapbender version are you using?
> Most likely a synchronisation issue, you might have to change the
> position of some modules...maybe increase loadwmc's position in "edit
> GUI elements" in the admin GUI and see; it should be loaded after the
> wms modules I guess.
> I have never tested this feature with an uncustomized Mapbender, so it
> might not be stable.
> Thanks
> Christoph
> David Arndt schrieb:
>> Hello,
>> I get a javascript error when I load a WMC from session:
>> mb_execloadWmcSubFunctions is not defined
>> Where can I find this function, maybe there is a typing error?
>> Regards, David Arndt.
>> geoinformation+planung
>> reichert+partner ingenieure
>> gölzstr. 22 72072 tübingen
>> fon: +49 (0)7071-407360
>> fax: +49 (0)7071-407361
>> geoinformation+planung - reichert+partner |
>> http://www.geoinformation-planung.de
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 25
> Fax: +49 (0)228 / 90 90 38 - 11
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080108/ae40ca95/attachment-0001.html
More information about the Mapbender_users
