[Mapbender-users] Javascript error mb_execloadWmcSubFunctions
    David Arndt
    arndt at geoinformation-planung.de
    Tue Jan  8 10:19:49 EST 2008
   Hello,
   in my case it is not a syncronisation issue, I inspected the code
with firebug and the function "mb_execloadWmcSubFunctions" is not been
loaded into the GUI.
   Do you have a hint, where I can find this function?
   Thanks, David Arndt.
   Quoting David Arndt <arndt at geoinformation-planung.de>:
>    It is Mapbender 2.4.4
>    Thanks, David Arndt.Quoting "Christoph Baudson (WhereGroup)"
> <christoph.baudson at wheregroup.com>:
>> David,
>> which Mapbender version are you using?
>> Most likely a synchronisation issue, you might have to change the
>> position of some modules...maybe increase loadwmc's position in "edit
>> GUI elements" in the admin GUI and see; it should be loaded after the
>> wms modules I guess.
>> I have never tested this feature with an uncustomized Mapbender, so it
>> might not be stable.
>> Thanks
>> Christoph
>> David Arndt schrieb:
>>> Hello,
>>> I get a javascript error when I load a WMC from session:
>>> mb_execloadWmcSubFunctions is not defined
>>> Where can I find this function, maybe there is a typing error?
>>> Regards, David Arndt.
>>> geoinformation+planung
>>> reichert+partner ingenieure
>>> gölzstr. 22 72072 tübingen
>>> fon: +49 (0)7071-407360
>>> fax: +49 (0)7071-407361
>>> geoinformation+planung - reichert+partner |
>>> http://www.geoinformation-planung.de
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> W h e r e G r o u p GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Christoph Baudson
>> Anwendungsentwickler
>> Fon: +49 (0)228 / 90 90 38 - 25
>> Fax: +49 (0)228 / 90 90 38 - 11
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Arnulf Christl, Olaf Knopp, Peter Stamm
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080108/e5e6d2bf/attachment.html
More information about the Mapbender_users
