[Mapbender-users] Summary of Mapbender irc meeting, 07.12.2007
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Tue Jan 8 05:28:06 EST 2008
This is a short summmary of last Monday's, Jan 7th 2008, irc meeting
http://www.mapbender.org/index.php/IRC_Meeting
See the irc-log-file: http://logs.qgis.org/mapbender/%23mapbender.2008-01-07.log
Next meeting will be on Monday, Jan 14, 17.00 UTC+1
Roll Call
Christoph, Michael, Thomas, Marc, Uli, Marko, Astrid, Melchior
Topics
1) License header in scripts
a) use PHP Doc to wrap license header
this was widely regarded as a good idea
b) link to the license to save space and avoid redundancy
we were discussing where to link to. To a local file or to an URL (GNU
site or Mapbender site)? Michael took responsibility and will consult
Arnulf, an expert.
2) Mapbender 2.5 (to do list, see
http://lists.osgeo.org/pipermail/mapbender_dev/2008-January/000963.html
and follow-ups)
a) AJAX module needs to be removed from all GUIs
Astrid volunteered to do the job.
b) SLD branch needs to be merged into trunk
Michael and Joschka are still testing, will probably happen next week.
c) what GUIs will we have in 2.5?
postponed
d) work on the tickets labeled as "Milestone 2.5 release"
postponed
e) Where to put the version number of Mapbender?
Kicked off by Marko's idea back in September:
http://lists.osgeo.org/pipermail/mapbender_dev/2007-September/000685.html
The idea is to have the version number of Mapbender hardwired, so that
Mapbender "knows" what version it has. There were various ideas - in
mapbender.conf - a new constants.php file - a new version.txt file
We still need to work out which solution will be best.
Marko proposed to also store the version number in the database in order
to check if the database is compatible to the software, which was
believed to be a sensible idea.
f) Have a release branch for Mapbender 2.5
No objections here
3) how to handle database changes
The idea is to abandon the dbchanges in the wiki, and replace them by
maintaining the update SQL files in the SVN. Was accepted.
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
