[Mapbender-users] RE: problem with wms after importing gui on server
karsten vennemann
karsten at terragis.net
Tue Jan 15 06:20:07 EST 2008
Hi I still experience problems when I try to import GUIs originating from my
local windows machine to my linux server (both mapbender 2.4.3). The gui
seems to import fine but when I try to upload the WMS on the server again it
gives me a message
"duplicate key violates unique constraint "pk_gui_layer""
I don't know how I could possibly have a duplicate key ... nor what/which it
could be...
The WMS is at
http://alliance.terragis.net/cgi-bin/mapserv?map=/var/www/mapdata/projects/a
lliance/alliance.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
Weird is that I can upload the same WMS (which is located on the server) and
it works on my local machine, but I can' succeed to upload it on the server
itself.
What can I do to fix it. Delete mabender db and start over again ?
I also tried the db cleaning script from
http://www.mapbender.org/index.php/Database-cleaning-script with no success
after running it.
What is the proper order to recreate a project on the server ?
Import GUI first or up load WMS to a different container-GUI first?
Thanks
Karsten
-----Original Message-----
From: karsten vennemann [mailto:karsten at terragis.net]
Sent: Thursday, January 03, 2008 00:54
To: 'mapbender_users at lists.osgeo.org'
Subject: Re: problem with wms after importing gui on server
Happy new year all,
Ok - my mistake I fiddled around with the wms in the meantime (trying to fix
it) and added a second layer on the wms on the server that broke the whole
thing.
Now the wms seems to be working again at
lliance/ok_server.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
gives me an xml output file.
I can use this wms successfully on my local machine but not on the server
(which serves the wms !) ???
I could now import the gui on the server without any errors (that showed
before - see below), but the wms data doesn't show up nor does the wms on
the administration interface (same as before).
I also tried to figure out if I had some junk in the db, thus renamed the
wms on the localhost, copied gui to new name , deleted the old wms , added
new one, exported as sql and imported on server - still the same problem
(works on localhost but not on server).
When I load the mapbender app from the server get the following error in
firebug:
wms[0] has no properties
mb_mapObj_const("mapframe1", "maps", "625", "400", null)map.php (line 19)
mb_registerMapObj("mapframe1", "maps", null, "625", "400")map.php (line 7)
init_mod_map1()mod_map1.php (line 17)
onload(load )mod_map1.php (line 1)
[Break on this error]
this.epsg=wms[0].gui_wms_epsg;this.extent=setExtent(this.width,this.height,t
his....
Anybody any hints what I can try to fix this ?
Karsten
Date: Tue, 1 Jan 2008 16:15:30 +0100 (CET)
From: "Ulrich Rothstein" <uli.rothstein at wheregroup.com>
Subject: Re: [Mapbender-users] problem with wms after importing gui on
server
To: "Mapbender User List" <mapbender_users at lists.osgeo.org>
Message-ID: <33245.212.79.172.164.1199200530.squirrel at vogon.ccgis.de>
Content-Type: text/plain;charset=iso-8859-1
Hey Karsten,
I just get an error-message if I try to load the capabilities document:
msLoadMap(): General error message. Undefined overlay symbol "POINT" in
class 0, style 1 of layer Active Attorneys. msAddImageSymbol(): Unable to
access file. Error opening image file
/var/www/mapdata/projects/alliance/POINT.
regards
Uli
On Sat, December 29, 2007 9:04 am, karsten vennemann wrote:
> Hi list,
> I'm working with mapbender 2.4.3 and created a gui including one wms
> (http://alliance.terragis.net/cgi-bin/mapserv?map=/var/www/mapdata/project
> s/ alliance/ok_server.map
> <http://alliance.terragis.net/cgi-bin/mapserv?map=/var/www/mapdata/projec
> ts/ alliance/ok_server.map&> &) on my local windows machine. There all is
> working fine. I then exported the gui as sql and imported into the
> mapbender database (postgis) on my linux server. The gui shows up on the
> admin pages after I ran Insert into gui_mb_user Values
('ocla1',1,'owner');
> However, the wms does not show up when I load the gui, also I can't find
> my wms in the table "wms" nor does it show up when I try to edit the wms
> under Configue WMS access> WMS GUI settings in the WMS_TiTle list box.
> I don't know whether a wms belonging to a gui usually is exported with the
> gui - or whether I have to recreate that resource on the server again?
> Thus, I tried to recreate the wms with "load capabilities", however
> trying to load
> s/a lliance/ok_server.map
> ts/
> alliance/ok_server.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0>
> gives me a violation of a constraint :-(:
> Warning: pg_exec() [function.pg-exec
> <http://alliance.terragis.net/php/function.pg-exec> ]: Query failed:
> ERROR:
> duplicate key violates unique constraint "pk_gui_layer" in
> /var/www/sites/mapbender/http/php/database-pgsql.php on line 133
> sql error: ERROR: duplicate key violates unique constraint "pk_gui_layer"
> ROLLBACK performed....
> Now I'm stuck and don't know how to port gui and wms to the server. Any
> ideas what went wrong, or how I can fix this?
> Karsten
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstra_e 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementdrin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
End of Mapbender_users Digest, Vol 14, Issue 1
More information about the Mapbender_users
