[Mapbender-users] MB 2.5rc2: internationalizd module "tabs"
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Mon Jun 9 04:00:18 EDT 2008
Schönhammer, Herbert schrieb:
> Hi list,
> I want to get module tabs working with MB 2.5.rc2.
> This module is not working in the example gui's "gui" and "gui2",
> which are delivered by mapbender 2.5rc2.
> (Firebug says "init is not defined"; don't know which "init")
> There is no tab_titles[] - Array in the element-vars for this module,
> of course. The module should be internationalized.
> But what can I do, to get the "tabs" working ?
> Where/How are the tab_titles now configured in the international
> context ?
> Only looking at table "translations" isn't really a help for me !
> regards
> Herbert Schoenhammer
Hello,
we created a page in the wiki with a description how you can update your
Mapbender to 2.5. There are some steps you have to do, but I hope
everything works fine when you follow the instructions.
Have a look at:
http://www.mapbender.org/Database_Changes_2.5
If you have anything to add, feel free to edit the wiki page.
Best regards Astrid Emde
--- deutsch -----
Im Mapbender Wiki gibt es die Seite
http://www.mapbender.org/Database_Changes_2.5. Hier wird beschrieben,
welche Schritte notwendig sind, um eine bestehende Mapbender
Installation nach Version 2.5 umzuziehen.
Gleichzeitig wird beschrieben, was sich an den einzelnen Elementen
geändert hat.
Ich hoffe, die Beschreibung ist vollständig. Falls es noch Ergänzungen
geben sollte, können diese gerne direkt im Wiki hinzugefügt werden.
Schönen Gruß Astrid Emde
More information about the Mapbender_users
