[Mapbender-users] Problems with EPSG
Sandra Mink sanmink at hotmail.com
Mon Jun 16 11:57:48 EDT 2008
Hi list,
I'm using geoserver 1.6.4 and mapbender with a Postgis database to put my maps on the web as a part of a project. I'm really a newbie to all this. After having a lot of trouble I finally made it and I got to see my layers, but ... they appear to be a mirror image and distorted. I realized they are projected in EPSG 4326, although I defined EPSG 32761 in geoserver, where everything worked well. Also the scale doesn't seem to work.
When I change EPSG in the Mapbender GUI it returns an error. And I don't know how to add other EPSG in the dropdown list in the WMS GUI Settings Menu. I've tried to make some edits but haven't had luck!
I need to use EPSG: 32761: Universal Polar Stereographic because I'm working on a area near Antarctica.
I've seen on the posts that somebody else had similar problems. I would appreaciate every kind of help! Is there a way to solve this?
Many thanks!
Sandra
_________________________________________________________________
Tecnología, moda, motor, viajes,…suscríbete a nuestros boletines para estar siempre a la última
Guapos y guapas, clips musicales y estrenos de cine.
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080616/dda91e09/attachment.html
More information about the Mapbender_users mailing list
