[Mapbender-users] Problems with EPSG
Sandra Mink
sanmink at hotmail.com
Tue Jun 17 06:58:55 EDT 2008
Hi, again!
Many thanks Len and Astrid for your quick responses!
Len, I have edited the changeEPSG and added a row with the 32761 EPSG.Now I can select 32761 in the GUI but it doesn't work because I get the following error message:
"Failed to load WMS .. from server ... Do you want to try it in a new window?"
To avoid more problems right now I have only one WMS loaded, mine from geoserver. It's true that in the WMS to GUI settings menu it is set to 4326, but I don't know how to change it...
Astrid, I have looked at the layer_epsg and it seems that there is a layer only with EPSG 4326. I think it is not really a layer in geoserver, but the Title I gave to the WMS configuration. That's what I see:
id: 0 parent: name: Elefante WMS title: Elefante WMS queryable: 0 minScale: 0 maxScale: 0dataurl: metadataurl:
EPSG:4326
-178.20351006019976
-50.07764976069634
-177.64443958125736
-49.81625887166632
layerstyle:
name
title
legendurl
legendurlformat
id: 1 parent: 0 name: ele:Linea de costa title: coast_Type queryable: 1 minScale: 0 maxScale: 0dataurl: metadataurl:
EPSG:4326
-178.20351006019976
-50.07764976069634
-177.64443958125736
-49.81625887166632
EPSG:32761
-2644018.138249832
1809033.7193695423
-2609670.4495129166
1855366.7973831547
I have added a row to the table with the BoundingBox limits as you told me. But now my question is (perhaps a very simple one) how do I update this values in mapbender? I have tried it with the update WMS but I don't see any changes???
I would be very, very thankful if you help me to solve this!
Vielen, vielen Dank!!
Sandra
> Date: Tue, 17 Jun 2008 11:23:26 +0200> Subject: RE: [Mapbender-users] Problems with EPSG> From: astrid.emde at wheregroup.com> To: mapbender_users at lists.osgeo.org> > Hello Sandra,> > the problem is that GeoServer does not serve the BoundingBox-Tag in the> XML. GeoServer only offers the LatLonBoundingBox in 4326.> > Here is an examle with UMN MapServer:> -----------> <Layer queryable="0" opaque="0" noSubsets="0">> <Name>myRootLayer</Name>> <Title>myRootLayer</Title>> <SRS>epsg:31466</SRS>> <SRS>epsg:31467</SRS>> <SRS>epsg:4326</SRS>> <LatLonBoundingBox minx="6.93635" miny="50.8018" maxx="7.01256"> maxy="50.8501" />> <BoundingBox SRS="EPSG:31466" minx="2.566e+006" miny="5.62995e+006"> maxx="2.5713e+006" maxy="5.63525e+006" />> ....> ------> > Mapbender can only start with the EPSG-Code, where Mapbender has a> corresponding BBOX.> > If you want to add a BoundingBox and an EPSG to start your gui with this> EPSG, you have to add a new row in the Mapbender table layer_epsg.> > Find out the layer_id of you root layer and add a new row for the> EPSG-Code you are interested in.> > After that you should have the possiblity to choose this new EPSG from the> dropdown list in the WMS GUI Settings.> > Greetings from Bonn> > astrid> > On Mon, June 16, 2008 6:17 pm, Len Kne wrote:> > Sandra> >> > I'm not familiar with geoserver, but it sounds like geoserver is rendering> > the map properly and not the issue. Couple ideas in Mapbender. First, I> > would suggest turning off the change ESPG module while troubleshooting -> > once it works, bring it back. Depending on which version of Mapbender you> > are using, you may have may have to add a line of code to changeESPG.php> > to> > include your projection. The scale bar also does not work properly in> > lat/lon (4326), but should be ok once you get to your projection.> >> > In the Admin module, look at "WMS GUI settings". The top WMS of an> > application/gui sets the default projection. I'm guessing your first WMS> > is> > set to 4326. You might have to move your WMS from geoserver to the top> > position, thus allowing you to select 32761 projection.> >> > Len> >> >> > _____> >> > From: mapbender_users-bounces at lists.osgeo.org> > [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of Sandra Mink> > Sent: Monday, June 16, 2008 10:58 AM> > To: mapbender_users at lists.osgeo.org> > Subject: [Mapbender-users] Problems with EPSG> >> >> > Hi list,> >> > I'm using geoserver 1.6.4 and mapbender with a Postgis database to put my> > maps on the web as a part of a project. I'm really a newbie to all this.> > After having a lot of trouble I finally made it and I got to see my> > layers,> > but ... they appear to be a mirror image and distorted. I realized they> > are> > projected in EPSG 4326, although I defined EPSG 32761 in geoserver, where> > everything worked well. Also the scale doesn't seem to work.> > When I change EPSG in the Mapbender GUI it returns an error. And I don't> > know how to add other EPSG in the dropdown list in the WMS GUI Settings> > Menu. I've tried to make some edits but haven't had luck!> >> > I need to use EPSG: 32761: Universal Polar Stereographic because I'm> > working> > on a area near Antarctica.> >> > I've seen on the posts that somebody else had similar problems. I would> > appreaciate every kind of help! Is there a way to solve this?> >> > Many thanks!> >> > Sandra> >> >> > _____> >> > Sigue de cerca las últimas tendencias y lo que más rompe MSN Vídeo> > <http://video.msn.com/video.aspx?mkt=es-es>> >> > _______________________________________________> > Mapbender_users mailing list> > Mapbender_users at lists.osgeo.org> > http://lists.osgeo.org/mailman/listinfo/mapbender_users> >> > > Mit freundlichen Grüßen> > Astrid Emde> > ----------------------------------> > Astrid Emde> WhereGroup GmbH & Co.KG> Siemensstraße 8> D-53121 Bonn> > Fon: +49(0)228 90 90 38 - 19> Fax: +49(0)228 90 90 38 - 11> > astrid.emde at wheregroup.com> www.wheregroup.com> > ----------------------------------> > _______________________________________________> Mapbender_users mailing list> Mapbender_users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/mapbender_users
_________________________________________________________________
MSN Noticias
http://noticias.msn.es/comunidad.aspx
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080617/d0f11bf9/attachment-0001.html
More information about the Mapbender_users
