[Mapbender-users] Problems with EPSG
Sandra Mink
sanmink at hotmail.com
Tue Jun 17 08:40:19 EDT 2008
Thank you soooo much!!!! It works... :-)
> Date: Tue, 17 Jun 2008 14:15:35 +0200> Subject: RE: [Mapbender-users] Problems with EPSG> From: astrid.emde at wheregroup.com> To: mapbender_users at lists.osgeo.org> > Hi Sandra,> > just some more information to get your WMS runnig:> > Go to admin2_en - WMS GUI settings. Klick on your WMS and have a look at> the layers. The Layer with Nr. 0 i your root layer. Find out the layer_id.> > Run the following SQL (replace the <layer_id>):> INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy)> VALUES (<layer_id>, 'EPSG:32761',> -2644018.138249832,1809033.7193695423,-2609670.4495129166,1855366.7973831547);> > Go again to admin2_en - WMS GUI settings and coose the WMS. You should> now have the possibility to choose the new EPSG.> > Best regards astrid> > On Tue, June 17, 2008 12:57 pm, Sandra Mink wrote:> > Hi, again!> >> > Many thanks Len and Astrid for your quick responses!> >> > Len, I have edited the changeEPSG and added a row with the 32761 EPSG.Now> > I can select 32761 in the GUI but it doesn't work because I get the> > following error message:> >> > "Failed to load WMS .. from server ... Do you want to try it in a new> > window?"> > To avoid more problems right now I have only one WMS loaded, mine from> > geoserver. It's true that in the WMS to GUI settings menu it is set to> > 4326, but I don't know how to change it...> >> > Astrid, I have looked at the layer_epsg and it seems that there is a layer> > only with EPSG 4326. I think it is not really a layer in geoserver, but> > the Title I gave to the WMS configuration. That's what I see:> >> > ....> > id: 0 parent: name: Elefante WMS title: Elefante WMS queryable: 0> > minScale: 0 maxScale: 0dataurl: metadataurl:> >> >> >> >> > EPSG:4326> > -178.20351006019976> > -50.07764976069634> > -177.64443958125736> > -49.81625887166632> > layerstyle:> >> >> >> >> > name> > title> > legendurl> > legendurlformat> > id: 1 parent: 0 name: ele:Linea de costa title: coast_Type queryable: 1> > minScale: 0 maxScale: 0dataurl: metadataurl:> >> >> >> > EPSG:4326> > -178.20351006019976> > -50.07764976069634> > -177.64443958125736> > -49.81625887166632> >> > EPSG:32761> > -2644018.138249832> > 1809033.7193695423> > -2609670.4495129166> > 1855366.7973831547> > ...> >> > I have added a row to the table with the BoundingBox limits as you told> > me. But now my question is (perhaps a very simple one) how do I update> > this values in mapbender? I have tried it with the update WMS but I don't> > see any changes???> >> > I would be very, very thankful if you help me to solve this!> > Vielen, vielen Dank!!> >> > Sandra> >> >> >> >> >> >> >> Date: Tue, 17 Jun 2008 11:23:26 +0200> Subject: RE: [Mapbender-users]> >> Problems with EPSG> From: astrid.emde at wheregroup.com> To:> >> mapbender_users at lists.osgeo.org> > Hello Sandra,> > the problem is that> >> GeoServer does not serve the BoundingBox-Tag in the> XML. GeoServer only> >> offers the LatLonBoundingBox in 4326.> > Here is an examle with UMN> >> MapServer:> -----------> <Layer queryable="0" opaque="0" noSubsets="0">>> >> <Name>myRootLayer</Name>> <Title>myRootLayer</Title>>> >> <SRS>epsg:31466</SRS>> <SRS>epsg:31467</SRS>> <SRS>epsg:4326</SRS>>> >> <LatLonBoundingBox minx="6.93635" miny="50.8018" maxx="7.01256">> >> maxy="50.8501" />> <BoundingBox SRS="EPSG:31466" minx="2.566e+006"> >> miny="5.62995e+006"> maxx="2.5713e+006" maxy="5.63525e+006" />> ....>> >> ------> > Mapbender can only start with the EPSG-Code, where Mapbender> >> has a> corresponding BBOX.> > If you want to add a BoundingBox and an> >> EPSG to start your gui with this> EPSG, you have to add a new row in the> >> Mapbender table layer_epsg.> > Find out the layer_id of you root layer> >> and add a new row for the> EPSG-Code you are interested in.> > After> >> that you should have the possiblity to choose this new EPSG from the>> >> dropdown list in the WMS GUI Settings.> > Greetings from Bonn> > astrid>> >> > On Mon, June 16, 2008 6:17 pm, Len Kne wrote:> > Sandra> >> > I'm not> >> familiar with geoserver, but it sounds like geoserver is rendering> >> >> the map properly and not the issue. Couple ideas in Mapbender. First, I>> >> > would suggest turning off the change ESPG module while troubleshooting> >> -> > once it works, bring it back. Depending on which version of> >> Mapbender you> > are using, you may have may have to add a line of code> >> to changeESPG.php> > to> > include your projection. The scale bar also> >> does not work properly in> > lat/lon (4326), but should be ok once you> >> get to your projection.> >> > In the Admin module, look at "WMS GUI> >> settings". The top WMS of an> > application/gui sets the default> >> projection. I'm guessing your first WMS> > is> > set to 4326. You might> >> have to move your WMS from geoserver to the top> > position, thus> >> allowing you to select 32761 projection.> >> > Len> >> >> > _____> >> >> >> From: mapbender_users-bounces at lists.osgeo.org> >> >> [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of Sandra> >> Mink> > Sent: Monday, June 16, 2008 10:58 AM> > To:> >> mapbender_users at lists.osgeo.org> > Subject: [Mapbender-users] Problems> >> with EPSG> >> >> > Hi list,> >> > I'm using geoserver 1.6.4 and> >> mapbender with a Postgis database to put my> > maps on the web as a part> >> of a project. I'm really a newbie to all this.> > After having a lot of> >> trouble I finally made it and I got to see my> > layers,> > but ... they> >> appear to be a mirror image and distorted. I realized they> > are> >> >> projected in EPSG 4326, although I defined EPSG 32761 in geoserver,> >> where> > everything worked well. Also the scale doesn't seem to work.> >> >> When I change EPSG in the Mapbender GUI it returns an error. And I> >> don't> > know how to add other EPSG in the dropdown list in the WMS GUI> >> Settings> > Menu. I've tried to make some edits but haven't had luck!>> >> >> > I need to use EPSG: 32761: Universal Polar Stereographic because> >> I'm> > working> > on a area near Antarctica.> >> > I've seen on the> >> posts that somebody else had similar problems. I would> > appreaciate> >> every kind of help! Is there a way to solve this?> >> > Many thanks!> >>> >> > Sandra> >> >> > _____> >> > Sigue de cerca las últimas tendencias y lo> >> que más rompe MSN Vídeo> > <http://video.msn.com/video.aspx?mkt=es-es>>> >> >> > _______________________________________________> > Mapbender_users> >> mailing list> > Mapbender_users at lists.osgeo.org> >> >> http://lists.osgeo.org/mailman/listinfo/mapbender_users> >> > > Mit> >> freundlichen Grüßen> > Astrid Emde> >> >> ----------------------------------> > Astrid Emde> WhereGroup GmbH &> >> Co.KG> Siemensstraße 8> D-53121 Bonn> > Fon: +49(0)228 90 90 38 - 19>> >> Fax: +49(0)228 90 90 38 - 11> > astrid.emde at wheregroup.com>> >> www.wheregroup.com> > ----------------------------------> >> >> _______________________________________________> Mapbender_users mailing> >> list> Mapbender_users at lists.osgeo.org>> >> http://lists.osgeo.org/mailman/listinfo/mapbender_users> > _________________________________________________________________> > MSN Video.> > http://video.msn.com/?mkt=es-es> > > Mit freundlichen Grüßen> > Astrid Emde> > ----------------------------------> > Astrid Emde> WhereGroup GmbH & Co.KG> Siemensstraße 8> D-53121 Bonn> > Fon: +49(0)228 90 90 38 - 19> Fax: +49(0)228 90 90 38 - 11> > astrid.emde at wheregroup.com> www.wheregroup.com> > ----------------------------------> > _______________________________________________> Mapbender_users mailing list> Mapbender_users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/mapbender_users
La vida de los famosos al desnudo en MSN Entretenimiento
http://entretenimiento.es.msn.com/
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080617/046c9e15/attachment-0001.html
More information about the Mapbender_users
