AW: [Mapbender-users] Ausdruck von Luftbildern / Printing aerial
	images
    Kai Behncke
    Kai-Behncke at gmx.de
    Wed Jun 18 09:47:00 EDT 2008
Thank you for all your hints, it works now!
I wrote in the Mapfile the following:
MAP
NAME           'luftbilder'
STATUS ON
IMAGETYPE     PNG
EXTENT        3595000 5904140  3621500  5919000
UNITS          METERS
SIZE        2000 2000
 IMAGECOLOR 255 255 255
SHAPEPATH   	'/..........................
 OUTPUTFORMAT
  NAME png
  DRIVER "GD/PNG"
  MIMETYPE "image/png"
  IMAGEMODE RGB
  FORMATOPTION  INTERLACE=OFF
  TRANSPARENT OFF
 END
 OUTPUTFORMAT
  NAME png8
  DRIVER "GD/PNG"
  IMAGEMODE PC256
  TRANSPARENT OFF
 END#
 OUTPUTFORMAT
  NAME GTiff
  DRIVER "GDAL/GTiff"
  MIMETYPE "image/tiff"
  IMAGEMODE RGB
 END
 OUTPUTFORMAT
  NAME imagemap
  MIMETYPE "text/html"
  FORMATOPTION SKIPENDTAG=OFF
  DRIVER imagemap
 END
.....and the image in the print looks perfect!
Thank you very much, Kai
-------- Original-Nachricht --------
> Datum: Wed, 18 Jun 2008 11:46:20 +0200
> Von: "Michael Schulz" <mschulz at webgis.de>
> An: "Mapbender User List" <mapbender_users at lists.osgeo.org>
> Betreff: Re: AW: [Mapbender-users] Ausdruck von Luftbildern / Printing aerial	images
> Hi Kai,
> before answering complete rubbish, I double checked whether the pngs
> embedded in the pdf are actually 24bit. But they are.
> >>From looking at the code, mapbender creates img obj with
> imagecreatetruecolor and copies all wms images into that image. the
> wms images are requested again with a getmap request but with the
> format set to "image/png". You have to make sure, that your mapserver
> spits out 24bit images also when requested with image/png and not only
> with "image/png; mode=24bit".
> How do the images look in the mapbender application, when the wms
> format is set to image/png and not image/png; 24bit? That's my
> outputformat:
>   IMAGETYPE PNG
>   DEBUG on
>   OUTPUTFORMAT
>     NAME PNG
>     DRIVER "GD/PNG"
>     IMAGEMODE RGBA
>     EXTENSION "png"
>   END
> The only difference is that i'm using alpha transparency, hmm... Do
> you have both options image/png and image/png;mode=24bit in your
> getcapabilities? What version of mapserver are we talking about?
> Keep on trying ;-) The solution to switch the mapfiles is surely a
> way, I'think you could achieve the same, by setting the processing
> parameters to your png outputformat and use jpeg in the browser
> (because for the print the map would be requested with png...).
> Cheers, Michael
> Am 17. Juni 2008 16:06 schrieb Kai Behncke <Kai-Behncke at gmx.de>:
> > Hi Michael, thank you.
> > You mean you made it somehow to integrate 24bit pngs in the
> Mapbender-Print?
> > Great, but what exactly did you do?
> > Well, at "WMS Gui Enstellungen" in Mapbender I choose "image/png;
> mode=24 bit".
> > In the WebGIS it looks fine but in the print everything else than that.
> > How did you define the OUTPUTFORMAT?
> > I tried it with:
> > MAP
> > NAME           'luftbilder'
> > STATUS ON
> > IMAGETYPE     PNG
> > UNITS          METERS
> > SIZE        500 500
> > SHAPEPATH       '/home/deichbau/daten/luftbilder'
> > OUTPUTFORMAT
> >  NAME png
> >  DRIVER "GD/PNG"
> >  IMAGEMODE RGB
> >  EXTENSION "png"
> > END
> > ....but the result is not what I want.
> > Best regards, Kai
> >> Datum: Tue, 17 Jun 2008 15:33:15 +0200
> aerial images
> >> Hi Marc, Kai,
> >> I think Marc is right: Kai, your pretty surely using jpeg for aerial
> >> images, but the pdf print code sets the format to png
> >> (classweldmaps2png.php, line 49). I never had problems using 24bit
> >> png's, so perhaps Kai can set an outputformat png with rgb, in order
> >> to avoid the usual mapserver "png; 24bit" format. Then you should get
> >> good looking (huge) aerial images in the pdf.
> >> Cheers, Michael
> >> Am 17. Juni 2008 15:00 schrieb Marc Jansen <jansen.marc at gmx.de>:
> >> > Hi Kai,
> >> > could you post  the FORMAT-Parameter (png, gif, etc.)  which you
> >> request?
> >> > AFAIK the PDF-lib used in Mabender is incapable of 24bit-PNGs
> (enabled
> >> e.g.
> >> > with IMAGEMODE RGB in UMN Mapserver). Furthermore, your problem
> >> description
> >> > makes me think of a JPEG which is transformed to a PNG when adding to
> >> the
> >> > PDF. But that is pure guessing.
> >> > -- Marc
> >> > Hi Kai,
> >> > könnntest Du den Parameter FORMAT (png, gif, etc.) mal an die Liste
> >> senden?
> >> > Sowei ich weiß kann die vomn Mapbender verwendete PDF-lib nicht mit
> 24
> >> bot
> >> > PNGs unmgehen (im UMN Mapserver z.B. via IMAGEMODE RGB
> >> bereitgestelllt),.
> >> > Die Problembeschreibung könnte allerdings auch (hier rate ich) auf
> ein
> >> JPEG
> >> > hindeuten, welches vom PDF-Module bei einbettung in das PDF in ein
> PNG
> >> > umgewandelt wird. (weldMapsToPng).
> >> > -- Marc
> >> > Kai Behncke schrieb:
> >> >> Hi Markus,
> >> >>> ich habe mich selbst noch nicht ausgiebig damit beschäftigt. Es
> gibt
> >> aber
> >> >>> beim Mapbender das Druckmodul, bei dem man die Auflösung (dpi)
> >> einstellen
> >> >>> kann, mit der das Bild für den Druck angefordert wird (Für den
> Druck
> >> >>> benötigt man in der Regel höhere Auflösungen als für den
> >> Bildschirm).
> >> >>> Man
> >> >>> muss dabei nur gewährleisten, dass der Mapserver die hohe
> Auflösung
> >> >>> bringt,
> >> >>> ansonsten gibt es eine weiße Seite.
> >> >> ja, das klappt einwandfrei, mit Mapfiles wo Werte mit 4
> multipliziert
> >> >> werden ist das hochaufgelöste Resultat  prima, bis auf die
> Luftbilder.
> >> Die
> >> >> Luftbilder sehen sowohl bei 72dpi als auch 288 dpi miserabel aus.
> >> >> Hmmm....scheinbar wird bei der Einbettung ins PDF da irgendwas mit
> den
> >> >> Bildern gemacht (nur was?).
> >> >> Viele Grüße, Kai
> >> > _______________________________________________
> >> > Mapbender_users mailing list
> >> > Mapbender_users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> >> Michael Schulz
> >> in medias res
> >> Gesellschaft für Informationstechnologie mbH
> >> In den Weihermatten 66
> >> 79108 Freiburg
> >> Tel +49 (0)761 556959-5
> >> Fax +49 (0)761 556959-6
> >> http://www.webgis.de / http://www.zopecms.de
> > Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
> > Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
> Michael Schulz
> in medias res
> 79108 Freiburg
GMX startet ShortView.de. Hier findest Du Leute mit Deinen Interessen!
Jetzt dabei sein: http://www.shortview.de/?mc=sv_ext_mf@gmx
More information about the Mapbender_users
