[Mapbender-users] Re: Automatic login in Mapbender 2.4.4
Joscha Laubach
laubach at iai.uni-bonn.de
Fri Mar 14 10:24:52 EDT 2008
Hello,
The describes problem only occurs if I try to automatically log in more
than once per session (first time it works). If I delete the
session-cookie the automatic login works again. Really strange. :-)
Regards,
Joscha
Joscha Laubach wrote:
> Hello Mapbender list,
> I am using Mapbender 2.4.4 and I automatically login to different GUIs
> with this mechanism:
> http://www.mapbender.org/index.php/GUI_Start_Parameters
> It worked without problems in older Mapbender versions, but not in
> v2.4.4. Is that a known problem or is it just my installation?
> When I try to login I get the Login-window. There I can insert username
> and password and then I can choose the GUI from the list. That works,
> but the automatic login doesn't. Strange. :-)
> Regards,
> Joscha
More information about the Mapbender_users
