[Mapbender-users] Re: Automatic login in Mapbender 2.4.4
Joscha Laubach laubach at iai.uni-bonn.de
Fri Mar 14 10:32:50 EDT 2008
Hello,
I just came up with the solution. It is not a problem with Mapbender. I
was using a Proxy, but my Testserver could not be reached by this proxy.
That obviously solved the problem. If I turn off the proxy, everything
works just fine.
Regards,
Joscha
Joscha Laubach schrieb:
> Hello,
> The describes problem only occurs if I try to automatically log in more
> than once per session (first time it works). If I delete the
> session-cookie the automatic login works again. Really strange. :-)
> Regards,
> Joscha
> Joscha Laubach wrote:
>> Hello Mapbender list,
>> I am using Mapbender 2.4.4 and I automatically login to different GUIs
>> with this mechanism:
>> http://www.mapbender.org/index.php/GUI_Start_Parameters
>> It worked without problems in older Mapbender versions, but not in
>> v2.4.4. Is that a known problem or is it just my installation?
>> When I try to login I get the Login-window. There I can insert
>> username and password and then I can choose the GUI from the list.
>> That works, but the automatic login doesn't. Strange. :-)
>> Regards,
>> Joscha
More information about the Mapbender_users mailing list
