[Mapbender-users] Mapbender creates maps with epsg 4326 only
Tilo Wütherich
tilo.wuetherich at la-bw.de
Thu May 29 11:13:30 EDT 2008
Hi Robert,
> I do have the same problem as Tilo.
> Does someone find a solution to offer more than one projection
> (4326) from GeoServer to Mapbender?
use MB 2.4.2 or newer. You should then get a select field in the gui-wms
settings. But I had a lot of trouble with the geoserver cap-docs, so I
always rework them in a text-editor and e.g. kick out the 4000+ projections
I don't need :->
Cheers,
Tilo
More information about the Mapbender_users
