AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
Schönhammer, Herbert Schoenhammer.Herbert at Regensburg.de
Tue Nov 4 05:16:40 EST 2008
Hello Mr. Scholle,
thank you for your reply.
I'm using SLES10 as Server-OS. That's fix, my IT wants this server.
I've tried now FF 3.x, IE7 and now the latest Opera. It's all the same.
But I had just a look in the webserver error_log. I get the following error-message when saving the the wmc:
 PHP Fatal error:  Class 'DOMDocument' not found in /home/mapbender/mapbender_2.5/http/classes/class_wmc.php on line 239
Will a developper or something else have a tipp for further "researches" ?
Thanks
 -----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Burghardt.Scholle at stadt.wolfsburg.de
Gesendet: Dienstag, 4. November 2008 08:37
An: mapbender_users at lists.osgeo.org
Betreff: AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
Hello Mr. Schönhammer,
I still have the same problems in a system combination with Ubuntu 8.04 (Server) and the IE6 (Client). With FF or IE7 I don't have any Problems. In a system combination Debian Etch/Lenny (Server) and any Browser I don't have any problems with save/load WMC too. Perhaps you can try another combination to test the behavior of the module mod_savewmc.php. Unfortunately I don't know a solution for the first combination.
Greetings
Burghardt Scholle
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org]Im Auftrag von Schönhammer, Herbert
Gesendet: Dienstag, 4. November 2008 08:16
Betreff: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
Hi list,
I want to generate a WMC-Document with MB 2.5 using the module mod_savewmc.php.
Clicking the button "Save workspace as Web Map Context Document" I am asked for the name of the workspace.
And that was all.
The wmc-document ist not offered using module mod_loadwmc.php. MapBender does not create an entry in mb_error_logs.
I don't find any record in the table mb_user_wmc or any file on the server or an my client.
I have tried all combinations with the var saveInSession:
- the var was set / unset
- the var was filled with the values 0/1
- the var was filled with the values true/false
The behaviour is reproducable with the shipped guis gui1 and gui2.
Where is the problem ?
Has anybody a solution for me ?
Greetings
Schönhammer Herbert
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20081104/cbb9b5ec/attachment.html
More information about the Mapbender_users mailing list
