[Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
Michael Schulz mschulz at webgis.de
Tue Nov 4 05:42:08 EST 2008
Hi Mr. Schoenhammer,
what version of php are you using?
Cheers,
Michael Schulz
2008/11/4 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
> Hello Mr. Scholle,
> thank you for your reply.
> I'm using SLES10 as Server-OS. That's fix, my IT wants this server.
> I've tried now FF 3.x, IE7 and now the latest Opera. It's all the same.
> But I had just a look in the webserver error_log. I get the following
> error-message when saving the the wmc:
>  PHP Fatal error:  Class 'DOMDocument' not found in
> /home/mapbender/mapbender_2.5/http/classes/class_wmc.php on line 239
> Will a developper or something else have a tipp for further "researches" ?
> Thanks
> Herbert Schoenhammer
>  -----Ursprüngliche Nachricht-----
> Von: mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von
> Burghardt.Scholle at stadt.wolfsburg.de
> Gesendet: Dienstag, 4. November 2008 08:37
> An: mapbender_users at lists.osgeo.org
> Betreff: AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
> Hello Mr. Schönhammer,
> I still have the same problems in a system combination with Ubuntu 8.04
> (Server) and the IE6 (Client). With FF or IE7 I don't have any Problems. In
> a system combination Debian Etch/Lenny (Server) and any Browser I don't have
> any problems with save/load WMC too. Perhaps you can try another combination
> to test the behavior of the module mod_savewmc.php. Unfortunately I don't
> know a solution for the first combination.
> Greetings
> Burghardt Scholle
> [mailto:mapbender_users-bounces at lists.osgeo.org]Im Auftrag von Schönhammer,
> Herbert
> Gesendet: Dienstag, 4. November 2008 08:16
> Betreff: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
> Hi list,
> I want to generate a WMC-Document with MB 2.5 using the module
> mod_savewmc.php.
> Clicking the button "Save workspace as Web Map Context Document" I am asked
> for the name of the workspace.
> And that was all.
> The wmc-document ist not offered using module mod_loadwmc.php. MapBender
> does not create an entry in mb_error_logs.
> I don't find any record in the table mb_user_wmc or any file on the server
> or an my client.
> I have tried all combinations with the var saveInSession:
> - the var was set / unset
> - the var was filled with the values 0/1
> - the var was filled with the values true/false
> The behaviour is reproducable with the shipped guis gui1 and gui2.
> Where is the problem ?
> Has anybody a solution for me ?
> Greetings
> Schönhammer Herbert
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
