AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
Christoph Baudson christoph.baudson at wheregroup.com
Tue Nov 4 06:54:05 EST 2008
Hello,
do you have the DOM library installed in PHP? Just check via phpinfo().
Christoph Baudson
Schönhammer schrieb:
> Hello Mr. Scholle,
> thank you for your reply.
> I'm using SLES10 as Server-OS. That's fix, my IT wants this server.
> I've tried now FF 3.x, IE7 and now the latest Opera. It's all the same.
> But I had just a look in the webserver error_log. I get the following
> error-message when saving the the wmc:
>  PHP Fatal error:  Class 'DOMDocument' not found in
> /home/mapbender/mapbender_2.5/http/classes/class_wmc.php on line 239
> Will a developper or something else have a tipp for further "researches" ?
> Thanks
> Herbert Schoenhammer
>  -----Ursprüngliche Nachricht-----
> *Von:* mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] *Im Auftrag von
> *Burghardt.Scholle at stadt.wolfsburg.de
> *Gesendet:* Dienstag, 4. November 2008 08:37
> *An:* mapbender_users at lists.osgeo.org
> *Betreff:* AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
>     Hello Mr. Schönhammer,
>     I still have the same problems in a system combination with Ubuntu
>     8.04 (Server) and the IE6 (Client). With FF or IE7 I don't have
>     any Problems. In a system combination Debian Etch/Lenny (Server)
>     and any Browser I don't have any problems with save/load WMC too.
>     Perhaps you can try another combination to test the behavior of
>     the module mod_savewmc.php. Unfortunately I don't know a solution
>     for the first combination.
>     Greetings
>     Burghardt Scholle
>         [mailto:mapbender_users-bounces at lists.osgeo.org]*Im Auftrag
>         von *Schönhammer, Herbert
>         *Gesendet:* Dienstag, 4. November 2008 08:16
>         *Betreff:* [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
>         Hi list,
>         I want to generate a WMC-Document with MB 2.5 using the module
>         mod_savewmc.php.
>         Clicking the button "Save workspace as Web Map Context
>         Document" I am asked for the name of the workspace.
>         And that was all.
>         The wmc-document ist not offered using module mod_loadwmc.php.
>         MapBender does not create an entry in mb_error_logs.
>         I don't find any record in the table mb_user_wmc or any file
>         on the server or an my client.
>         I have tried all combinations with the var saveInSession:
>         - the var was set / unset
>         - the var was filled with the values 0/1
>         - the var was filled with the values true/false
>         The behaviour is reproducable with the shipped guis gui1 and gui2.
>         Where is the problem ?
>         Has anybody a solution for me ?
>         Greetings
>         Schönhammer Herbert
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Where2B-Konferenz
Die Geo-IT Konferenz der WhereGroup
vom 9.-10. Dezember 2008 in Bonn
Web: www.where2b-conference.com
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
